I tried searching but can't find anything similar to my problem. When I plug in my ebp sensor it reads 174psi with engine running or off. With sensor unplugged reads 24psi. Harness looks fine and swapping sensors doesn't change anything. I have no boost and is slow as he'll. any suggestions? It's an 06 btw with egr delete, studs and all the basics
Thanks
hope you find your answer, my problem is similar, i get 0 or 1 at KOEO when it should read 14.7, swapped it out for a new one and still the same, reads about 6 at idle. my main issue is excessive turbo flutter. Bump this to the top
im not sure, turbo flutter in these trucks is fairly common during hard acceleration, im sure there are tons of youtubes you can check, if yours doesnt sound like a typical turbo flutter you may have something different going on then i do
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
