I apologize if this a repeat topic, new to the forum. please redirect if necessary.
My 03 6.0 suddenly dies, like its been shut off at the ignition. I recently had the ficm replaced after massive power loss issues. there was one stall while the power loss was happening, but it was attributed to the ficm issue. no more power issues, however the stalling is now happening. after a fill up when the truck was warm it stalled at a stop and started right back up and then repeated the process. i drove it home while it kept stalling and figured out i could keep it running if i revved it above 1000 rpm. it will die and i can put it in neutral and restart immediately. there was only one instance of no start for 30 seconds. my check engine light is on and the codes being thrown are the csp and ckp sensors. local shop suggested changing those sensors first. i know they are often thrown after a long crank, but am concerned they are problems and being shrugged off. any suggestions? i was also thinking stc fitting on the hpop or a wiring harness issue. open to any and all suggestions! thanks!
