FICM ? - Page 2 - Ford Powerstroke Diesel Forum
 9Likes
post #11 of 64 Old 12-07-2008, 02:24 PM Thread Starter
simpleman 6.0's Avatar
Thanks for all the info. Engine light is not on but i do have a loss in power. It might be a ground wire because the cab was just off or the latest flash comming from the dealer.
MIKE 2004 F250 C/CAB 4X4 KING RANCH
4" BANKS MONSTER EXHAUST
SCTX3 AUTOMETER 3 GAGE A-PILLAR POD
ACCUFAB SMALL MOUTH POWER ELBOW
.ALPINE DVD JL AUDIO IN DOORS & IN BACK JL AMPS L7 KICKER10 IN CUSTOM PORTED CONSOLE
.4"PRO COMP LIFT W/ 305/70/18 MT BAJA ATZ W/KMC DIESELS
[IMG]
simpleman 6.0 is offline
post #12 of 64 Old 12-07-2008, 02:26 PM Thread Starter
But will the truck still run with a bad ficm?
[IMG]
post #13 of 64 Old 12-07-2008, 02:26 PM
Goose350's Avatar
Mine is at Ford right now because of the FICM. Went to start my truck one morning and she never would fire. Had to get it towed to Ford
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #14 of 64 Old 12-07-2008, 02:53 PM
jhaddox's Avatar
Send a message via AIM to jhaddox
i had to get a new ficm about 2 months ago...they have a ton of different symptoms...mine just had a rough idle and it would sputter when you were driving...no start is another one...id go get it checked out
08 ECSB 6.4
MPD, GOGO, No Limit, Rudys, ARP, PMF, Innovative, AFE, Recon, Fuel, Nitto, Bilstein
jhaddox is offline
post #15 of 64 Old 12-07-2008, 03:20 PM Thread Starter
It's gonig to the shop on the 15th.
[IMG]
post #16 of 64 Old 12-07-2008, 03:27 PM
Sparkplugs Not Required
Someone said this is like a $1500 fix? I might have to go find a good used spare....
Ed
2005 F-250 4x4 CC LB
ARP Head Studs
4" MBRP Turbo Back Exhaust, no kitty
SCT XCal3 with ID Tunes
Isspro Gauges
Nitto Terra Grapplers 305/70R17
CAT797 is offline
post #17 of 64 Old 12-07-2008, 03:38 PM
Goose350's Avatar
The FICM itself is about $900 without labor. My total was just over $1300 and that including the tow ride to ford and some other thing that didnt have to do with the FICM but it was only like $50
The Mullet Mod
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #18 of 64 Old 12-08-2008, 01:20 PM
goodriddance's Avatar
mines going in tomorrow to have the ficm replaced, what started my problem was a TON of white smoke on start up, had the heat inductive flash put in and would still blow tons of white smoke above 2k rpms, when the ficm was tested with the lap top, it was at 38 at idle then the more gas you gave it it dropped to 30 as where it should be at 46 I believe, and YES your truck will still run with a failing ficm but how well depends how bad it is
Bear 1 likes this.
goodriddance is offline
post #19 of 64 Old 12-08-2008, 02:54 PM Thread Starter
THANKS FOR ALL RESPONSES.
[IMG]
post #20 of 64 Old 12-08-2008, 03:00 PM
Goose350's Avatar
I just got my truck back today and a new FICM was 843.54 from Ford.
The Mullet Mod
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
