2004 6.0 excessive white smoke, and coolant loss in exhaust - Ford Powerstroke Diesel Forum
post #1 of 30 Old 12-02-2008, 08:11 PM Thread Starter
Please help.... I am new to this site, and applaud all my fellow powerstroke owners. Your time and insight are appreciated. My 04 F350 recently started pushing white smoke and coolant loss thru exhaust. I am only losing a small amount of coolant. There is no puking thru the bottle, and my oil appears to be clean. I had minor choking a few times in the neighborhood. I took the EGR valve out, it was a little carboned up, but was not wet with coolant. WAs thinking it was an EGR cooler, and was leaning towards buying a bypass kit, and moving on. How do I know if this is the problem. My truck has 145k, miles, and the only other issue I had was the intercoler hose was blowing off at the turbo, months ago. The truck is bone stock. Please help.....
Thanks in advance
AZchief is offline
post #2 of 30 Old 12-02-2008, 08:17 PM
67ModStang's Avatar
Send a message via AIM to 67ModStang Send a message via Yahoo to 67ModStang
I would have to second the EGR cooler. Try parking on a decline with the front of the truck pointing down and then pull the egr valve to see if there any coolant in there. I would go ahead and do the delete anyway if I was you. Nothing stopping you since you're out of warranty and you won't ever have to worry about it again
Jered
GONE
1967 Mustang Coupe 5.4L Lightning, 2.3 Whipple, Viper T56
2011 Mustang GT 5.0 Stock
2005 F-150 Lariat 4x4
2004 Excursion EB 4x4
67ModStang is offline
post #3 of 30 Old 12-02-2008, 08:20 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
EGR cooler. With the miles I would do an Oil cooler too.
post #4 of 30 Old 12-02-2008, 08:20 PM Thread Starter
When I do an EGR delete to I need to do anything to the oil cooler? DO I assume it is good, or should I check it? And how can you check them?
AZchief is offline
post #5 of 30 Old 12-02-2008, 08:22 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
Theres about a 97% chance your oil cooler is what caused the egr cooler to go out at that mileage. Put an oil cooler in it to.
post #6 of 30 Old 12-02-2008, 08:22 PM
Powerstroke Diesel Enthusiast
Diesel_Diagnostician's Avatar
I agree with 67modstang but, I am a true believer in the coolant pressure tester (about a hundred bones for a snap on) and especially if you are or wanting to be a dyi kinda guy. Id pressurize the system overnight and check to see how much pressure you loose and then you can go ahead and inspect your intake for signs of coolant.
-You can think I'm wrong, but that's no reason to quit thinking-
Diesel_Diagnostician is offline
post #7 of 30 Old 12-02-2008, 08:23 PM
Rice Hunter
Diesel Freak's Avatar
White smoke ..... surprised your EGR valve is not wet. When cleaning your EGR valve ...Does the plunger snap back closed and tight? Any power loss? Still reading turbo boost?
May want to do a pressure test to rule out blown head gaskets. I'm also favored for deleting EGR cooler and welding valve shut.
Hopefully a tech will chime in
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #8 of 30 Old 12-02-2008, 08:23 PM
I second the oil cooler idea.
post #9 of 30 Old 12-02-2008, 08:24 PM Thread Starter
Are there any disadvantages with not replacing the EGR cooler, and bypassing it? Also which bypass kit should I buy, or use a homemade solution? Thanks for your help.
AZchief is offline
post #10 of 30 Old 12-02-2008, 08:27 PM
Rice Hunter
Coolers fail pretty often. Could also wash out your oil cooler
Custom Tuned SCT
S.S. Brake Lines
ARP Head Studs
EGR Delete
'03 Turbo Swap
