*HELP*6.0 HARD START/LONG CRANK TIME - Ford Powerstroke Diesel Forum
post #1 of 47 Old 11-12-2008, 06:38 PM Thread Starter
Unhappy *HELP*6.0 HARD START/LONG CRANK TIME
PURCHASED NEW 2006 F350 CREW 6.0 W/15,000 MI.,PAST FEW MONTHS EXPERIENCING HARD STARTING ISSUES/LONG CRANK TIMES PRIMARILY WHEN COLD.REPLACED BOTH FUEL FILTERS, NO CHANGE.TOOK TO DEALER REPLACED ICP SENSOR,HIGH PSI PUMP,CA REGULATOR??,& CLEAN TURBO,NO IMPROVEMENT.NOT SO SURE IT IS A HIGH OIL PRESURE ISSUE THINKING MORE LIKE FUEL RELATED,AFTER LONG CRANK AND TRUCK FINALLY FIRES IF YOU SHUT IT RIGHT DOWN AND TRY TO RESTART, IT DOES FIRE ALOT QUICKER.GOING TO TRY PLUGGING IT IN TONIGHT FOR THE 1ST TIME,SEE WHAT HAPPENS??
PLEASE HELP!!!
maya1 is offline
post #2 of 47 Old 11-12-2008, 06:41 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
What kind of oil are you using? What is the ambient temperature where you are located?
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #3 of 47 Old 11-12-2008, 06:45 PM
fsas's Avatar
I've been having the same issues for about 2 months now. The tech at the dealership said my batteries were weak, and that was causing the problem because everything else seemed fine. I bought brand new batteries ( about 900 cold cranking amps) and no change. Still takes at least twice as long to fire than when I first bought it. However, If I drive it around a little, it will start right up like normal. No idea....
2006 F350 Lariat FX4
SCT Xcal3 - Phantom II gauges
2.5" suspension leveling kit
20" KMC Rockstar Wheels
BFG T/A KO's 305/55/r20
SS Custom Grill & Inserts
Custom painted VentVisors
4" MBRP exhaust w/ 5" stainless tip
Airaid intake
HD Headlights w/ HID
35% tint front/ 5% tint back
Pioneer double din DVD head unit
Infinity 6x8's
2 x Infinity 8" subs in custom enclosure --Replaced with shallow mount 10"
"The past is just your future with the lights on"
fsas is offline
post #4 of 47 Old 11-12-2008, 07:11 PM Thread Starter
ROTELLA 15W40,EAST COAST 40-50 DEG.
maya1 is offline
post #5 of 47 Old 11-12-2008, 07:30 PM
Stoker0560's Avatar
05 F350 97k ...I am having same problem! starts really hard and bangs around when it first fires for a few seconds..average temp is about low 40s..starts great when plugged in..the other morning it got about 30 overnight and i my cord wasnt plugged in the garage and i litterally had to hold the starter while it fired for at least 10 seconds! BAD! it started like an old mack truck in 10 degree weather! last winter it always banged alittle when cold but it always started right away! dealer told me i should run 10w30 and it should fix it..im not thinkin so! if im not mistaken i shouldnt even have to worry about plugging it in untill near zero temp..currently running 15w40 rotella w/1 gt lucas..its due for a change 7k on oil last changed in april 08..maybe just need fresh oil??? need to figure this out..almost out of warranty! thanks
Stoker0560 is offline
post #6 of 47 Old 11-12-2008, 07:33 PM
f250ghost's Avatar
I had that problem with my 03. Take it to the dealership and have them re flash the PCM with the update. It fixed it on the spot...that was about a year ago. But I think I have an injector or starter going now...but yeah the flash defiantly fixes it.
-Ben
2011 F250 FX4
6.7 PowerStroke
f250ghost is offline
post #7 of 47 Old 11-12-2008, 07:33 PM
stroken04's Avatar
do you guys have the current flash from the dealer
stroken04 is offline
post #8 of 47 Old 11-12-2008, 07:41 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
GENTS, I would be inclined to agree with the poster who was advised by the dealer to run 10W30 oil. Remember, the injectors on these engines are controlled by high pressure ENGINE OIL. The thicker the oil, the greater the resistance to all moving parts inside the engine. I would also like to add to it. STAY AWAY from aftermarket oil filters.
m-chan68 is offline
post #9 of 47 Old 11-12-2008, 07:51 PM Thread Starter
AS FAR AS I KNOW I WOULD SAY NO,AT LEAST DEALERSHIP NEVER TOLD ME NOR WAS IT STATED ON ANY OF MY PAPERWORK.VERY DISGUSTED AT THIS POINT 2ND 6.0 AND NOTHING BUT TROUBLE.
maya1 is offline
post #10 of 47 Old 11-12-2008, 08:03 PM Thread Starter
I GUESS IT WOULDN'T HURT TO TRY 10-30 OIL ,BUT JUST DOESN'T MAKE SENSE RAN ROTELLA 15W-40 SINCE DAY 1 WITH NO ISSUES, SAME PROB. ABOUT 2 MONTHS AGO WHEN TEMPS WERE STILL IN 60-70 DEG. RANGE??
maya1 is offline
