*HELP*6.0 HARD START/LONG CRANK TIME - Page 5 - Ford Powerstroke Diesel Forum
post #41 of 47 Old 04-10-2009, 04:37 PM
dirtdieselmaniac09's Avatar
Send a message via AIM to dirtdieselmaniac09
i am having the exact same problem acttually just got back from the dealership about 2 hours ago i have a 04 6.0 with 180,000 on it they told me it was the ipr (injector pressure regulator) but not sure checked everything else as wel as replacin filter icp sensor to
WE ALL DO STUPID STUFF BUT ITS ALL FOR GOOD REASONS.........
4" exaust
zoodad
gauges
sct sf3
soon to come
4" turbo back with stacks
transmission
injectors
dirtdieselmaniac09 is offline
post #42 of 47 Old 04-10-2009, 05:20 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 331 Post(s)
I say you all need some reflashing done!!!! When i took my truck to the dealer i had to tell them to reflash my FICM Fuel Injector Control Module to fix my problem it costs 85 bucks in FL. The truck i had would start ok and run like crap till it warmed up.
@loxdce
LoxDiesel is offline
post #43 of 47 Old 04-10-2009, 07:03 PM
Yes
Hard starting dies on road
Well Back near Christmas 2008 that was the problem. You fellow powerstroker's said take it in for the reflash. I called up and had that plan in mind. After about two hours the tech told me to get a loaner and go home- "it is going to be a while” While they had it the replaced the PCM (Power Control Module). That unit is on the driver side next to the battery. Also replaced was the ICP sensor (not sure what that is). The EGR (exhaust gas recirculator) was also replaced. It must have done the trick. I went on an 800-mile trip averaging about 67 miles per hour and got 16 and 17 miles per gallon. That is up from twelve miles per gallon! Hats off to Ford, the only automaker in the USA not begging for a handout- they fixed the truck better than new. The dealer did not charge for the reflash either.
A little advice from this site: powerstrokehelp.com has made me more confident about my 6.0. Bill also has some great suggestions on how to care for your 6.0. It is just to bad his shop is in Georgia. I live in Ohio. My truck started and ran fine all winter and is still running like a scared rabbit.
I am still using Wix filters as I have for the past 25 years in everything I own. There was no mention of Wix filters by the dealer as any part of the problem or a contributing factor. I thought Wix might be a problem after reading some of the threads posted here.
Keep on trucking. Cheers!
Last edited by Yes; 09-22-2010 at 05:04 PM. Reason: Wrong state for powerstrokehelp.com
Yes is offline
post #44 of 47 Old 04-10-2009, 08:30 PM
I love my 06 pwrstroke, I just got it back from the dealer. they replaced all sorts of parts. It made no difference when starting it up, no white smoke, which is good. At the dealership there was this man with a 2006 f 250 diesel that was telling me that he replaced 2 turbos, alternator and battery. The sad part is that his rig has only 26,000 mi Man I would really hate to get rid of my truck
2006pwrstroke is offline
post #45 of 47 Old 04-11-2009, 06:54 PM
Dr. of Linemantology
quequeg37's Avatar
re-flash & 10w-30
seems crazy, i know, but the thinner oil does work. i had the same cold start issues with my 04 6.0 with 62k miles and a re-flaswh from the dealer (about $100 bucks) and moving from the 15w-40 to the 10w-30 fixed the problem. has to be the high pressure rails above the in jectors. i have 2 injectors going bad but the oil make a day and night difference.
quequeg37 is offline
post #46 of 47 Old 09-21-2010, 11:50 PM
Since its started snowing already and the OAT keeps dropping I'm going to bump this.
I have an 03 6.0 that is causing some problems if I don't plug it in at night. I haven't had any cases where the truck wont start yet but it is getting harder every day. I am running 0W30 Syn so the oil shouldn't be an issue. It was changed ~600km ago. The truck smokes a lot on start-up and is very sluggish until fully warm. It also has a very bad shake when operating ~1300-1700 rpm until warm. Is this an injector issue? If so does anyone have a good supplier of stock injectors in Canada?
baxtair is offline
post #47 of 47 Old 09-22-2010, 05:02 PM
Yes
Not sure what OAT is but a guess is Outside Average Temperature. Any way Ford had some trouble with the 03 diesel 6.0L. It could be injectors dripping if it smokes at startup. Hard starting could also be the glow plugs. Have you owned it since new? Did anyone ever put a chip in it and work it hard? Are the heads leaking? I suggest a site called powerstrokehelp.com. I personally would not use 0W30 in anything I own. Not an old clunk or a new $50,000 truck. I do use synthetic oil in everything I own. Rotella 5w40 synthetic is what I use. Maybe the 0w30 oil is too thin to drive the injector pump. Get rid of that oil. If it is that cold in Canada, plug it in for an hour or so before you drive it.
Yes is offline
