6.0 wastegate - Ford Powerstroke Diesel Forum
post #1 of 22 Old 11-04-2008, 03:29 PM Thread Starter
wlsmithjr1960's Avatar
Send a message via Yahoo to wlsmithjr1960
6.0 wastegate
Went on a beach camping trip this past weekend with my 05 f250 psd crewcab FX4 pulling my 8,000lb travel trailer (190 mile trip). Going to the beach ran in tow/haul mode going down, no problems, then coming home Sunday, again, in tow/haul mode blew the lower boot off of pipe coming out of intercooler twice,both times going uphill and transmission changing to lower gear and turbo boost going up to around 25lbs. Was told that wastegate might be clogged up.
Any ideas? Everything on truck is stock. Thanks: wlsmithjr1960http://www.powerstroke.org/forum/images/smilies/icon_ford.gif
wlsmithjr1960 is offline
post #2 of 22 Old 11-04-2008, 03:36 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
A wastegate does not exist on a 6.0L. Instead it uses what's called a VGT (variable geometry turbine) on the exhaust side. Boost is controlled by what's called a VGT solenoid. What typically happens is the unison ring inside the turbo seizes up inside the housing due to excessive carbon buildup, and/or rust and corrosion, causing an overboost/underboost condition.
In your case, I would start by replacing the rubber CAC hose that keeps blowing off first. Rubber tends to swell up after prolonged exposure to engine oil, reducing its ability to seal properly.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #3 of 22 Old 11-04-2008, 03:42 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
You dont have a wastegate. Clean the intercooler pipes real good. and spray the boots with cheap hairspray. Then reattach them.
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 22 Old 11-04-2008, 03:46 PM Thread Starter
Thanks for reply, have already changed both boots with new ones, was going up the road around 4:30 this afternoon about half a mile from home and blew off again, I,m guessing from to much boost build up. any suggestions would be greatly appreciated. I live near Thomasville, NC, and don't know of to many 6.0 mechanics nearby. wlsmithjr1960
post #5 of 22 Old 11-04-2008, 03:50 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
How far from Winston Salem
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 22 Old 11-04-2008, 04:02 PM Thread Starter
30 minutes.wlsmithjr1960
post #7 of 22 Old 11-04-2008, 04:03 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
PM Scuffy828. Hes a Ford diesel tech there. Works for a dealer and owns his own shop. He should be able to set you up one way or the other
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 22 Old 11-04-2008, 04:11 PM Thread Starter
Thanks!!! wlsmithjr1960, any other ideas?
post #9 of 22 Old 11-04-2008, 04:35 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Springs on band clamps could be loose not allowing them to get tight enough to hold boost tube on.
dhanna6powerstroke is offline
post #10 of 22 Old 11-04-2008, 04:40 PM Thread Starter
Made sure all of them are tight. Then same one blew off again half a mile from home earlier this evening. I'm thinkin its blowing too much boost pressure for some reason. Thanks for response. wlsmithjr1960
