Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 01-07-2006, 05:11 AM
myscootisbad myscootisbad is offline
Angry 03 F350 6.0L Turbo/injectors
I just got my truck back today from dealer....went in for what was thought to be warranty work for poor performance....came out with dusted turbo....2 injectors (at least) bad....possible piston damage....y-pipe shot.....I was told that since I installed AFE cold air intake....i voided my waranty....they claimed that they filter flows more air and subsequently flows more dirt....this is what the tech told me....even though the air filter is better than original...they are still pointing finger at it. Anyone have any luck beating ford on this?? If so...how?? Have found a lot of people online that have the exact same problem.....Ford just looking for a cheap way out.
Old 01-07-2006, 06:46 AM
Rodslinger Rodslinger is offline
Gun Nut
Welcome to Powerstroke.org!
The dealer is full of......well I'm a moderator so I'll stop there.
Here look here;
http://www.afefilters.com/forums/vie...d13255fabf4f89
I'm getting a AFE Stage II myself so I've been looking into just that. Fight them and you'll win.
Old 01-07-2006, 07:07 AM
Gun Nut
Oh one more thing -
AFE claims their filtration systems FILTER and flow better than stock, so either Ford is wrong (my bet) or AFE is false advertising. Either way one of them is going to fix your rig and my money is on Ford having to do it.
Old 01-07-2006, 04:02 PM
Unklmyk Unklmyk is offline
I know what you're going through. Check out my posts "Warranty nightmare" and "Warranty voided". Ford seems to be looking for ANY excuse to hang the repair bill on the owner.
Old 01-07-2006, 04:16 PM
mschn99 mschn99 is offline
Banished
being a tech myself, i think both ford and the aftermarket companies are wrong. the aftermarket company is full of bull claiming that their filter will filter better than the OEM style sick-0 filter, because it is the same technology that big rigs run and is a very complex, layered filter design, but ford is also wrong in saying that an aftermarket airfilter could cause a dusted turbo in an engine under 100k......plus the fact that they can only void the base engine warranty even if it was true and the Y pipe is an exhaust part. even if they did not warranty the turbo, the y pipe should be covered. basically your getting lied to on multiple levels by ford, and by the better filtration claim by the aftermarket filter. you cannot filter better, and let more air through, this is impossible, in order to collect the smallest particles, you have to have smaller holes for the air to go through... and that means a little less airflow in. its simple physics.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
