BAD HFCM??? Low Fuel Pressure - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-12-2014, 04:02 PM Thread Starter
Ranger5.0l's Avatar
Had problems with truck gelling up and low fuel pressure at WOT but fine at idle. Getting back to warm weather and no more gelling still have low fuel pressure with BRAND NEW MOTORCRAFT filters. Pressure checked with mechanical gauge and my edge both reading the same.
I've noticed my hfcm is making abnormal noises now. Could it be going bad??
I also did the blue spring upgrade last winter but never had a gauge on it till now. So im starting to think i could of made a mistake while installing it but this seems less likely because i've noticed a steady drop in performance here just lately.
Ranger5.0l is online now
post #2 of 6 Old 02-12-2014, 06:48 PM
Blown F-150's Avatar
What is your PSI at idle and under load.
2006 F-350
Lariat, Crew Cab 4X4
EGR Delete, K&N Intake, MBRP Exhaust, Level kit, Custom Ford Badges, Tranny/EGT/Boost/Fuel Pressure Gauges.
Gryphon FICM tuner
SCT XCal 3 with custom tunes
ScanGauge II
Updated STC fitting
High idle mod, blue spring update.
Blown F-150 is offline
post #3 of 6 Old 02-12-2014, 08:20 PM Thread Starter
Ranger5.0l's Avatar
normal 60 psi idle, next to nothing Single digits at WOT but fine under normal crusing condtions
post #4 of 6 Old 02-13-2014, 10:44 AM
The pump could be weak, but it seems like more of a restriction issue. You may want to disconnect the line coming from the tank and see if you can put some air to it to ensure your foot in the tank isn't plugged up.
Pumps aren't that cheap, but I would order one and put it in. Order just the pump off of Ebay and save some pennies vs. the whole HFCM.
2006 F-350
Gryphon FICM tuner
ScanGauge II
Updated STC fitting
post #5 of 6 Old 02-13-2014, 04:34 PM Thread Starter
Ranger5.0l's Avatar
i plan on blowing all the lines out tomorrow. Hope thats the issue or I see myself spending the money to upgrade the factory fuel system
post #6 of 6 Old 02-18-2014, 02:02 PM Thread Starter
Ranger5.0l's Avatar
Blew all the lines out no change in pressure pump seems to be getting louder and seems to be alot of bubbles in my up fuel filet housing. I bought a new old style pump off ebay for 180$. Hope it fixes the issue
