*#@%#!*$^#in Oil Cooler, AGAIN!!! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-12-2014, 12:42 PM Thread Starter
sealeveloc's Avatar
Quoted: 19 Post(s)
Sorry about the "another oil cooler thread" but couldn't find any useful info in the ten million other oil cooler threads.
I just replaced my oil cooler less than 8,000 miles ago. Hauling the excavator today 48* delta. I know you don't check deltas when towing, but I shouldn't have a oil temp of 236* and water temp of 188*. So WTF..... Cruising 65mph for about 15-20 mins 22-25* delta
Little history, truck has 211K miles on it, I tore it all apart at 204k. I put in 190/30's from warren and new oil cooler, trans cooler, radiator, oem head gaskets, had heads checked and decked. Put it all back together, and fired up on 4-5th crank. Deltas were 2-3* difference, and have been slowly getting worse ever since. I am running cat ELC, and have a coolant filter.
I bought the oil cooler from sunrise ford, it came with instruction sheet from Maxx Force. Im assuming thats the oem replacement, is that correct? Im not looking to buy the bullet proof kit right now(want to get stage 3 turbo first,lol).
What else could be clogging it? I had the truck apart for almost 3 months, the water jackets in the block looked a little rusty when it all went back together, so i dunno if it has all broke free and went straight to the oil cooler or what. I guess I'm going to buy another oil cooler, and see what happens. Any suggestions, comments, or questions to help me with this are greatly appreciated.
Byron
O6 350 XL
The usual I wanna go fast mods,
maybe a lil more,
maybe a lil less
sealeveloc is offline
post #2 of 14 Old 02-12-2014, 01:37 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Hows your delta's when your doing the 60 mph flat lander test?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 14 Old 02-12-2014, 01:41 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
It may be a bit of the block rust, but the radiator or heater core are possibilities. Having it dry can create precipitate that cracks or peels free. Depending on the condition of the system prior to your first replacement, you could zero in on the problem. If you didn't try to flush the block prior to re-installing the cooler, that was probably the culprit. You may be able to back flush it.
Also, check to ensure your EOT sensor is reading correctly.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 14 Old 02-12-2014, 01:45 PM Thread Starter
sealeveloc's Avatar
Quoted: 19 Post(s)
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #5 of 14 Old 02-12-2014, 02:04 PM Thread Starter
sealeveloc's Avatar
Quoted: 19 Post(s)
I have a feeling that the rust is my problem. I have a new radiator that I got from BPD so it shouldn't be that. This is the 3rd oil cooler in the truck since new. I read a little on the back flush, kinda looks easier to just replace the oil cooler. I need my truck to run everyday for work purposes. (thats why I have it all turned up) Should I do the restore and restore plus again. I know one is for rust can't remember which. Where is oil temp sensor? thanks
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #6 of 14 Old 02-12-2014, 02:20 PM
Snake's Avatar
Quoted: 46 Post(s)
What are your numbers unloaded, no trailer at 60-65 mph? (ECT and EOT)
How heavy are you towing when you're seeing these big numbers? **edit** Am I the only one who thinks a 188* ECT is low when trailering an excavator?
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #7 of 14 Old 02-12-2014, 02:21 PM Thread Starter
sealeveloc's Avatar
Quoted: 19 Post(s)
Cruising 65mph for about 15-20 mins 22-25* delta unloaded.
I haul around 10-11k lbs
Edit: I replaced thermostat about 3000 miles ago too. Do to a low coolant temp. I had little to no heat in the truck. Got it from advanced auto I believe it was a 192* thermostat. ECT never went over 190 today.I hauled twice about 1.5 hrs each time. Flat land, besides over passes
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #8 of 14 Old 02-12-2014, 02:41 PM Thread Starter
sealeveloc's Avatar
Quoted: 19 Post(s)
And my fan never kicked in to where you really hear it. Trans temp was 151* max. Where is heater core and is there any way to test?
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #9 of 14 Old 02-12-2014, 05:43 PM
Blown F-150's Avatar
You may want to check your ECT* when the truck is cold. It is possible that it's off. You should be making more heat than that pulling that size of load.
Unless you have a massive air pocket causing issues, but I can't see that since it's been run quite a bit since you did the work.
2006 F-350
Lariat, Crew Cab 4X4
EGR Delete, K&N Intake, MBRP Exhaust, Level kit, Custom Ford Badges, Tranny/EGT/Boost/Fuel Pressure Gauges.
Gryphon FICM tuner
SCT XCal 3 with custom tunes
ScanGauge II
Updated STC fitting
High idle mod, blue spring update.
Blown F-150 is offline
post #10 of 14 Old 02-12-2014, 05:45 PM Thread Starter
sealeveloc's Avatar
Quoted: 19 Post(s)
Thanks man, oil and coolant are with in 2* on start up when cold
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
