Loud noise following head gasket repair - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By jeby64
post #1 of 10 Old 02-11-2014, 11:26 AM Thread Starter
Any help would be greatly appreciated.
I blew my head gasket and did the tear-down, repair, and build-up. The oil was pretty bad, like chocolate milk. Heads checked out good. After the repair, truck was putting out significant blue smoke and had a contribution 5 fault. Tried running it for ~200 miles (on advice from a friend) but was not clearing up, and then it started making a loup **whopping** noise. I replaced injector 5 but noise still remains. The noise sounds like it's coming from the turbo. Any advice would be greatly appreciated. Do I need to replace the turbo?
I'm trying to put a video up, but having problems with file format. If I get it figured out, I'll post the video.
Thanks for looking.
krappe is offline
post #2 of 10 Old 02-11-2014, 01:05 PM
hard to diagnose a noise based on a 'whoop' but im thinking maybe a stuck or something? bent pushrod? are you confident you got the pushrods lined up correctly? it is possible to miss the slot and put teh whole thing back together.
jeby64 is offline
post #3 of 10 Old 02-11-2014, 01:27 PM Thread Starter
Thanks for the reply. Yeah, I know, I wish I could provide a better description. I was pretty maticulous putting everything back together. But the noise did not appear until I ran the truck for a while, it was not there when I first ran it. My compression checks look good for 1, 3 & 7; 5 has no compression. So I expect I was dumping fuel into #5 and not burning it. Could that adversely impact the turbo?
krappe is offline
post #4 of 10 Old 02-11-2014, 01:34 PM
if 5 has no compression that is your problem. you are probably going to have to pull that head again. at least the valve cover and oil rail and check that no push rods are broken or something. you may need to pull it and get the valves rechecked. i suspect that whoop is loosing compression through the intake. meaning a valve isnt sealing. dont quote me on that, i just dont really see it being much else. dumping fuel would actually increase compression and cause a hydrolock.
john galt likes this.
jeby64 is offline
post #5 of 10 Old 02-11-2014, 01:49 PM Thread Starter
Thanks. I appreciate the feedback. I was able to convert the video and get it posted. Here it is.
Thanks again.
Ken
krappe is offline
post #6 of 10 Old 02-11-2014, 02:08 PM
Quoted: 9 Post(s)
I would agree with above. Could be a reall bad blown gasket, but if it were that bad you could probably feel it with your hand along the head somewhere and I would think water would also be an issue inexhaust or blowing out degas. I would look at your rockers and see if valves are closing.
divotf15 is offline
post #7 of 10 Old 02-11-2014, 03:42 PM
yeah that sounds like a dead miss to me. did you get the heads checked out by a machine shop before you put them back on?
jeby64 is offline
post #8 of 10 Old 02-11-2014, 06:41 PM
Intake valve is open. Might be bent or stuck open. Remove cover and oil rail to have a look.
2004 F350 6.0 FX4 Lariat Crew Cab Short Box SRW Egr Delete, ARP Studs, Coolant filter, Edge Juice with Attitude, Blue Spring Fuel Upgrade, Banjo Bolts, Straight Pipe Exhaust, 19X,XXX
partsmark72 is offline
post #9 of 10 Old 02-12-2014, 05:01 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Check your rockers/pushrods on cyl #5....
Please
You could save the life of a sick child
NYC F-350 is offline
post #10 of 10 Old 02-12-2014, 01:49 PM Thread Starter
Thank you all so much for your input. Yes, heads checked out good by machine shop. I do have a couple questions though, and I apologize for my ignorance in advance ...
How would I diagnose if my #5 did hydrolock? ... does the entire engine lock, or could #5 just lock and not compress?
And is there any way to diagnose if I blew a hole in #5 piston (or ring)?
At least I got my first steps, pull cover & oil rail to check rockers/pushrods. Thanks all.
krappe is offline
Tags
contribution fault , head gasket , turbo
