Fuel Gauge Short - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-10-2014, 11:56 AM Thread Starter
nola350's Avatar
Fuel Gauge Short
Occasionally when I start my 6.0 the fuel gauge does not raise up and my miles left on info center has all lines. I can restart a couple of times and it works as it should. This does not always happen, just every once in a while. Has anyone else experienced this?
Paul
2004 Excursion 6.0 Powerstroke
Edge Incite CTS (STOLEN OUT OF TRUCK)
Blue Spring Upgrade
Alpine IXA W404 Radio
Parrot Blue Tooth
Seafoam every other fill up
35" Nitto Terra Grappler All Terain Tires
Nathan Airchime K5LA Train Horns with compressor and 5 gallon tank with 1/2 OD Air Lines
Hellwig rear bar
Ford gold antifreeze
Rotella T6 oil with Rev X
Blisten steering stabalizer
4" Banks Monster Turbo back-Cat Delete
nola350 is offline
post #2 of 3 Old 02-11-2014, 01:08 PM
probably the sending unit in the tank. they very commonly go bad. and if it isnt giving a signal, the overhead trip computer cant tell you how many miles left.
jeby64 is offline
post #3 of 3 Old 02-11-2014, 07:40 PM Thread Starter
nola350's Avatar
So I guess it starting to tell me it will eventually go out. I guess that is one of those things I will wait until it goes out. Not looking forward to either raising the bed or dropping the tank. Thanks for the info.
Paul
Blue Spring Upgrade
Parrot Blue Tooth
Hellwig rear bar
nola350 is offline
