HELP with No start issue; BPD 58v FICM bad? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By SelahPSD
post #1 of 9 Old 02-10-2014, 09:53 AM Thread Starter
I need some of the collective wisdom of this forum. PROBLEM: I shut my truck off at 8:00 pm Saturday night. It was running fine. Sunday morning I went to start it and it cranked fine, but would not start. My CTS Insight showed 0.0 FICM voltage. So, I removed the top plate on the FICM and tested it with a voltage meter per Ron's videos on YouTube (with key off, and then while cranking). Results = 0.0 volts. I checked the FICM fuse and installed a new FICM relay. Same result--0.0 volts.
I found the following trouble codes:
P0611 FICM performance (this code has shown up since I upgraded the FICM)
P1000 On-Board Diagnostic OBD System Readiness Test Not Complete (this code has shown up since I installed the CTS Edge Insight monitor).
P1378 FICM Supply Voltage Circuit Low (this is a new code)
U0306 Software Incompatible With FICM (this code has shown up since I installed the PHP Atlas 40 FICM tune)
So, it appears that my FICM is dead! Correct? What could cause this--why would my FICM fail suddenly? My understanding is that the FICM rarely fails suddenly, and that they tend to fail more gradually.
Please note that I installed a Bulletproof Diesel 6-phase FICM with the 58v option about 15 months ago. I also installed a Power Hungry Performance Atlas 80 FICM tune about six month ago. Could my FICM have burned up? What else could it be? I haven't pulled the FICM yet, so I don't know what it looks like inside, and I have not been able to inspect the wire harness. The only other thing I should mention is that about three days before this problem occurred I installed LED dome lights. Is there some way this could've caused a problem?
All input is greatly appreciated!!
ROB
2006 F350 Lariat CC LB FX4 Dually Auto 4.10
MODS:
Edge Insight CTS
SCT X4 Quicktricks Custom Tunes
KC Stage 2
MBRP 4" Turboback Straightpipe Exhaust
BPD 58v FICM, PHP Atlas 80 Tune
IPR High Flow Coolant Filter
ARP Head Studs & EGR Delete
Blue Spring
DC Power 250 Amp Alt & Big 3 Upgrade
Interstate Mega-Tron Plus 65 Batteries
42" LED Light Bar
Fleetrite ELC Coolant
IPR Remote Oil Cooler
2008 Tow Mirrors
20" Meyhem Monstir Chrome Wheels
SelahPSD is offline
post #2 of 9 Old 02-10-2014, 10:37 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
I would remove the FICM and check the connections going into the bottom of it. I've never seen a bad FICM read 0 voltage when tested. Not saying it doesn't happen, just haven't seen it.
dhanna6powerstroke is offline
post #3 of 9 Old 02-10-2014, 11:41 AM Thread Starter
Thank you very much for your input. Actually, when I first realized I was having a no start problem, I checked my CTS gauge and the FICM voltage fluctuated between 1 to 5 volts. By the time I got the FICM exposed to check it with the voltage meter, I was getting a reading of 0.0 volts. However, I agree that there still is a possibility that the wiring harness has come loose or unplugged. I will check that out and report back. Thanks!!
ROB
MODS:
Edge Insight CTS
KC Stage 2
Blue Spring
42" LED Light Bar
2008 Tow Mirrors
SelahPSD is offline
post #4 of 9 Old 02-18-2014, 11:01 AM
Paulliewog's Avatar
just wondering, I have the same, or similar problem with my rig. What fixed your truck?
My truck had a BPD ficm supply set at 58 Volts and after about six months ran into long cranks to start. Eventually to the point there was no start at all. I found the 50 amp ficm fuse popped and replaced it only to have it pop again immediately. Called BPD and they sent me a new ficm supply, greatly appreciated, BTW!! Hooked it up, now the truck starts, but still have to hold crank on to get it to fire. Any help is greatly appreciated.
'05 F-350 King Ranch, lost the muffler.
can't find my cat???
SCT tuner, 58V Bulletproof Diesel 6 phase FICM upgrade
Paulliewog is offline
post #5 of 9 Old 02-21-2014, 05:55 PM Thread Starter
Paulliewog, I want to thank you for your post. Thanks to you, I checked my 50 amp FICM fuse and found that it was blown. So, for me it was a quick and cheap fix! However, I have not been able to determine why the fuse blew in the first place! I checked the FICM wiring harness, but did not detect any chafing issues. I hope you were able to get your truck running. If I learn any more about possible causes for the blown fuse issue, I will post you. Thanks again for your help!
Paulliewog likes this.
ROB
MODS:
Edge Insight CTS
KC Stage 2
Blue Spring
42" LED Light Bar
2008 Tow Mirrors
SelahPSD is offline
post #6 of 9 Old 02-22-2014, 05:10 PM
Paulliewog's Avatar
Kind of glad to hear that my truck woes are helping others out there. I'm working a bit on it here and there, and the truck does run now. Still have this long cranking and still starts and stalls. After a couple of times it finally starts and runs. Back at the drawing board tomorrow.
post #7 of 9 Old 02-23-2014, 04:23 PM Thread Starter
Paulliewog, I found something on YouTube that might be helpful. Here's the link: FORD Diesel ~6.0L & 7.3L~ Troubleshoot Hard or Won't Start Problems - YouTube. If the link does not work just let me know and I will email it to you. Thanks again for your help.
Rob
ROB
MODS:
Edge Insight CTS
KC Stage 2
Blue Spring
42" LED Light Bar
2008 Tow Mirrors
SelahPSD is offline
post #8 of 9 Old 02-24-2014, 05:32 AM
Paulliewog's Avatar
Thanks SelahPSD. Have to get ScanGuage II, hopefully soon, to monitor them. Saw the video and it will help a lot. Thanks again.
post #9 of 9 Old 06-17-2014, 11:05 AM
Paulliewog's Avatar
Been a while since I posted on this thread. After a long, cold and mean winter I had some time to look at the truck and with a favour from a local repair shop (owner is a good friend of mine) got a scan tool to borrow. As I am cranking, the high pressure oil slowly builds up. It takes about 5-10 seconds to get up to 500 psi, and then the truck starts. Obviously a leak somewhere, but I am going to just leave it for now. I have to do the head gaskets too. Maybe in 2015 I will git'er done!
Tags
bpd , ficm , no start
