White exhaust smoke smells like diesel fuel new rebuild - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-09-2014, 08:18 AM Thread Starter
We just put a rebuilt long block motor in a 2006 Ford F550, put new turbo, injectors, egr delete, High Pressure Oil Pump, Oil Cooler, etc on it as well. We start it up ran fine for first 5 seconds, then she started to blow white smoke out of the tailpipe that looked like one of them coal roller trucks except the smoke is white. Smokes white smoke even when just idling, although she smokes more when you idle up the engine. It is also hard to restart as the only way she wants to fire is if you rapidly pump the gas pedal. The rebuild was done with all stock OEM parts including injectors etc. Any help is greatly appreciated. Thank you
korarde is offline
post #2 of 4 Old 02-09-2014, 09:00 AM
M90Ranger's Avatar
Might have torn an O ring on one of the injectors.
It happens if the Rocker arm causes it to go off center on the way in.
M90Ranger is offline
The Following User Says Thank You to M90Ranger For This Useful Post:
korarde (02-09-2014)
post #3 of 4 Old 02-09-2014, 09:02 AM Thread Starter
Ok Thank you, we going to pull the glow plugs tomorrow and see if any of the glow plugs have fuel pouring out as we crank over the engine
korarde is offline
post #4 of 4 Old 02-10-2014, 10:38 AM
Pudder's Avatar
I had an 03 do this. Injector washed out... New motor needed after that, hopefully your not in the same boat
2011 F350 Crewcab 6.7 4x4 Bone Stock!
2004 F350 Crewcab 6.0 4x4, only 60k miles! EGR delete, BD coolant filter
Pudder is offline
