ficm problem - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-08-2014, 04:02 PM Thread Starter
ficm problem
ok guys im new to this but I had my ficm replaced on my 06 6.0 last year and my truck run good and started fine but now its doin the same hard starts and missing till it warms up could this be some thing else or is some thing causing my ficm to go bad and if so wood a 58v ficm from bulitproof fixe it thanks in advance
56 6.0 build is offline
post #2 of 4 Old 02-08-2014, 05:09 PM
SargentoPistola's Avatar
How's the rest of your electrical system? Batteries and alternator healthy?
-Kyle-
2004 6.0 Eddie Bauer Excursion. The Man Van.
SCT w/ MPD
Edge CTS w/ EGT Probe
Banks exhaust
EGR Delete
Coolant Filter
Riffraff Boots
Stuff
1999 F-150 XLT 4.6 4x2. The Backup.
SargentoPistola is offline
post #3 of 4 Old 02-08-2014, 05:21 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
What are the FICM volts koeo and while running? Sounds like a FICM module problem again. I would get a bulletproof FICM with the 6 phase since they have 2 extra redundant curcuits to fall back on just incase the primary ones decide to fail. Also the bulletproof FICM is compelety redesigned to help dissipate heat a lot better which is a another big problem with the OEM ones!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 4 Old 02-09-2014, 02:30 PM Thread Starter
I have new batts I but them on when it was down last time but alternator im not sure on I had been running a sct programmer but took it off when it started with the hard starts again
