6.0 Glow Plug Control Module testing - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By seanhoffman
post #1 of 3 Old 02-07-2014, 06:51 AM Thread Starter
ynpmoose's Avatar
Quoted: 7 Post(s)
I need to troubleshoot my P0671 glow plug soft code and found these docs. I think i can actually test through the GP bus bar harness plug to see if my GP resistance is correct without pulling the bus bar out (at least to start with). I also spoke to my local Ford dealer diesel tech (super awesome dude will answer all kind of questions, print out troubleshooting docs for you, etc.) and he seemed to think I am more likely to have a failed GPCM versus the GP itself, even though I'm only throwing a single cylinder code.
I'll give these docs a run-through tomorrow. I figure at the least I can maybe saved busting up a perfectly good bus bar only to find out the GP wasn't bad.
SOLD - 2003 Excursion 6.0L 4x4
ynpmoose is offline
post #2 of 3 Old 02-08-2014, 12:55 PM
Testing the module is easy. It right on top. Tons of videos on the subject. But having just replaced 1,3,5,6 GP i bet its just a glow plug. Do yourself a favor and watch some videos on removal using a screwdriver and some #10GA wire....works great when pulling the harness
asher628 likes this.
seanhoffman is offline
The Following User Says Thank You to seanhoffman For This Useful Post:
asher628 (07-29-2015)
post #3 of 3 Old 02-08-2014, 03:23 PM Thread Starter
ynpmoose's Avatar
Quoted: 7 Post(s)
Fixed it up today. Cylinder 1 GP ohm tested at 22 instead of .5 to 2 through the harness. I followed Dave's "through the wheelwell" instructions in the forum tech articles. I have the solid bus bar, so no wire needed. Just some gentle prying. My bus bar is only 6 months old so it wasn't brittle yet.
ynpmoose is offline
