Cold start smoke - how much is normal? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-07-2014, 06:44 AM Thread Starter
ynpmoose's Avatar
Quoted: 7 Post(s)
This is my first winter with this truck. Is this amount of smoke normal on a cold start?
I do have a soft code P0671 - Cyl 1 glow plug circuit. If I don't plug in, FICM momentarily drops to 45v on startup, then steady 47.5-48 when warm, so it is questionable. Batteries load tested OK.
Outside is 16F, block heater plugged in for 2-3 hours.
Thanks,
Moose
SOLD - 2003 Excursion 6.0L 4x4
ynpmoose is offline
post #2 of 5 Old 02-07-2014, 09:09 AM
Looks normal to me. Did you try to smell the white smoke? If it smells sweet there is an issue. Could be ruptured egr cooler or head gaskets. But it looks normal to me with the cold temps you are having.
6.OPowerstroke is offline
post #3 of 5 Old 02-07-2014, 09:24 AM Thread Starter
ynpmoose's Avatar
Quoted: 7 Post(s)
I did not smell it, but I'll do that. The dealer just put on new heads, gaskets, oil cooler, and egr cooler less than 5000 miles ago, so I think I'm good there.
ynpmoose is offline
post #4 of 5 Old 02-07-2014, 12:11 PM
04cr450's Avatar
need to look into this.. if i start mine up on a low teen morning, not plugged in, it will just puff out a good sized black smoke ball and then clear up right away..
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 5 Old 02-07-2014, 01:55 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
that's what mine looks like when its cold outside.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
