6.0 Coolant Flush quick question - Ford Powerstroke Diesel Forum
post #1 of 24 Old 02-07-2014, 05:13 AM Thread Starter
BRichards118's Avatar
I'm getting ready to do the coolant flush on my 05 f250 tomorrow and I have everything prepped and ready to go and I've read just about ever thread out there on the coolant flushes but one thing I never really came across was how long it takes people to do this entire process. So my question is how long does the coolant flush normally take? Should I devote the entire day or half a day or 4-5 hours????
Thanks
BRichards118 is offline
post #2 of 24 Old 02-07-2014, 05:18 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I spent pretty much most of the day doing mine. But I didnt rush things. Just kinda took my time.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 24 Old 02-07-2014, 05:46 AM Thread Starter
Ok I was thinking I'd have to use a whole day, especially since I live in MI and it's gonna be a huge pain in my a$$ to get the truck up to temp with no thermostat in 20 degree weather.
post #4 of 24 Old 02-07-2014, 05:49 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
just pull your tstat
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 24 Old 02-07-2014, 06:02 AM Thread Starter
I know I have to pull the tstat out but isn't it going to be really hard for me to get the truck up to operating temps with no tstat in the truck?
post #6 of 24 Old 02-07-2014, 06:11 AM
Quoted: 2 Post(s)
It'll get up to temp quicker without a tstat in place. Are you doing a chemical or water flush? Since I always start late in the day, it's always taken me about two days to do my flushes.
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
post #7 of 24 Old 02-07-2014, 06:37 AM Thread Starter
I'm doing the restore and restore plus flush. It's step 1 in a big project. After the flush I'm doing oil cooler, stc fitting, dummy plugs, stand pipes, egr delete and turbo cleaning
post #8 of 24 Old 02-07-2014, 06:38 AM Thread Starter
I'm filling coolant with peak final charge elc concentrate
post #9 of 24 Old 02-07-2014, 06:43 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
You dont have to pull the t stat. Just use the radiator drain and the block drain on drivers side each time you drain it and repeat until nothing but clear distilled water comes out then add your 4 gal. of consentrait red coolant. I used like 15 gal. of distilled water to get it all out. There is 4 gal. (8 gal. system) that you cant drain so repeated fill/drive/drain processes are needed.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #10 of 24 Old 02-07-2014, 07:31 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Pull the thermostat and use a big chunk of cardboard to cover a good portion of the radiator to aid in getting it to temp. Watch the coolant temps to ensure it doesn't overheat (I doubt it will)
Please
You could save the life of a sick child
NYC F-350 is offline
Tags
6.0 , coolant flush , elc coolant flush
