power loss and codes - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-05-2014, 12:16 PM Thread Starter
johnstroke's Avatar
Question power loss and codes
ok so yesterday i was driving home and my truck kept surging a little when on the highway at about 70 mph. and a little on accelration. also at idle it seems to be not stedy but the rpm is not changing much but i can hear it in the turbo noise. now today its loosing power like im running out of diesel but im not. so i checked for codes because my light never comes on. i think because i have the sct livewire on it but any way i got these codes p0046 p0069 p0403 p0478 p0603 p0683 i now what they are but dont want to just throw a bunch of new parts at it and still have a problem so trying to narrow it down also the egr is gone hence the 403. any help would be great
03 FX4 with
livewire and tunes from mike at MKM customs. EGR delete, zoodad mod,AIRAID intake, coolant filter, ccv reroute,remote trans filter kit, HID's, built in nav unit with back up cam and dvd, 20% tint,led lights inside and out,huskie mats,08 tailgate and rear lights,rhino lined bed,tripple guage pod with glowshift guages, boost,fuel,volts, headach rack,4'' DP with open exhust and 5'' SS tip,2.5 leveling kit with duel front shocks, 33'' goodyear tires and no payments mod.
johnstroke is offline
post #2 of 4 Old 02-06-2014, 04:49 AM
Quoted: 9 Post(s)
Do you have a scan tool such as autoenginuity. If you don't, I know you don't want to hear it, but you will probably pay for it with this fix alone.
I have had some of these problems. First, the P0046 code could cause a lot of these other codes. The 0046 will probably lead you to the vgt solenoid. That thing rarel, rarely, rarely goes bad. So, with the engine running at idle unplug the vgt solenoid a few times and see if you can hear the turbo operating. Normally at idle you will hear the exhaust "hissing" because it has the vanes moved to a minimum so that the exhaust velocity increases as it hits the turbine wheel. When you unplug the vgt the vanes should open up and the velocity is decreased and the "hissing" will go away. Sometimes you can even hear a little "whoosh" at the intake of the turbo when the turbo starts to spin down when you uplug it.
If you are not getting any change when you unplug it, I would look through the wiring for a fault/short. I had one that would work at idle, but when I got torque on the engine it moved a little and caused a short. Took me forever to realize it was a short and it ended up being all the way down into the main part of the harness as I cut open the corregated protection tubing and followed the wires until I found them shorted together due to chafing against each other.
If that turbo is not working correctly you can get low back pressure compared to what is being commanded or you can get very high back pressure.
Also, there is tube that runs from the MAP sensor to the intake manifold. Those are prone to getting old and brittle and they can crack and if they are leaking they screw everything up. Even if it is not cracked, take it off of the manifold and clean out the brass nipple that it goes on. Sometimes Carbon plugs that thing up.
Start with all of that. Again, if you had a scanner you could actually see what the baro and MAP are giving you as well as EBP. The vgt solenoid has no feedback system, but you can see what the duty cycle is supposed to be at any given time.
Good luck.
divotf15 is offline
post #3 of 4 Old 02-06-2014, 04:52 AM
Quoted: 9 Post(s)
Oh yeah,
Some people talk about the p0046 being stuck tubo vanes...... I don't think you can say that. P0046 is an electrical code saying something isn't right about the circuit. Since there is no feedback loop from the solenoid, there is no real way to say of the vanes are moving or not with that code.
divotf15 is offline
post #4 of 4 Old 02-06-2014, 12:35 PM Thread Starter
johnstroke's Avatar
i just checked all that and evey thing is good however i can hear the turbo wistle noise changing at idle with it pluged in when i unplug it it goes away do you think it could be the map it self going bad
03 FX4 with
