04' 6.0, fuel issue - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-02-2014, 06:25 PM Thread Starter
FHO
04' 6.0, fuel issue
I have an 04' 6.0. Just had #5 injector replaced about 1.5 weeks ago. Ran fine until yesterday. Was idling and went dead. Started right back up..ran 8-10 seconds with no miss.. Then died again. Will start every-time then do this. When it's running it's idles just fine. Thought it might be an oil level (pressure) issue, but it's fine. Also, both fuel filters are brand new. Any advice would appreciated.
Thanks
FHO is offline
post #2 of 4 Old 02-02-2014, 06:27 PM Thread Starter
FHO
Oh yeah...had the EGR deleted about 10,000 ago and new head studs put in. I use a 3015 SCT. I haven't gotten any codes either.
FHO is offline
post #3 of 4 Old 04-01-2014, 03:51 PM
breakinboats's Avatar
hey man im having the same problem will start idle fine then its like you just turn off the key did you end up finding out what was wrong
Intake, Exhaust, Custom FICM, Custom SCT, EGR Delete, Zoodad, CTS
Theres no such thing as to much torque
breakinboats is offline
post #4 of 4 Old 04-16-2014, 05:10 AM
Hi. Mine did the same. Had to go all the way down to the fuel tank. The plastic ring over the iron net wich filters the fuel was just in million pieces. The pieces were just floating and blocking the fuel flow. So maybe there´s something blocking the fuel flow into the system. Mine had ;-)
dieselsrule is offline
