Crank but no start - Ford Powerstroke Diesel Forum
post #1 of 21 Old 02-02-2014, 02:21 PM Thread Starter
7.3hotrod's Avatar
Crank but no start
Hi, guys my 2007 6.0 cranks but wont start. I've tested the F.i.c.m. and got 51.2VDC. Cranking the oil filter bowls pumps oil in and I changed fuel filters and manually primed it like my 7.3's. It started hard that day and then wouldn't start. It doesn't wanna give it up. My battery's have 1100 cold cranks in each of them. Please help I almost wish I never bought it, I've had four 7.3's without issue and this 6.0 is a problem child.
Maybe 2008 F-350 6.4 ZF6 H&S
2001 F-250 5.4 Off-Road 86,000 miles
7.3hotrod is offline
post #2 of 21 Old 02-03-2014, 03:31 AM
Quoted: 9 Post(s)
When you turn on the key, can you hear the injectors operate (buzz test)
do you have a scanner, not just a code reader?
If you do, what is the injector control pressure reading during start?
divotf15 is offline
post #3 of 21 Old 02-04-2014, 10:00 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Also check for FICM Sync. Also check the Fan harness and EBP sensor wires for damage or shorted out.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 21 Old 02-06-2014, 04:21 PM Thread Starter
7.3hotrod's Avatar
It has the buzz and the pump sounds dry like it isnt getting fuel? I'm going to borrow my buddy's international program reader. I use motorcraft filters I have used K&N I compared them side to side the are exactly the same size shape and color. I have leaking head gaskets to this truck is getting expensive. Lol
post #5 of 21 Old 02-06-2014, 04:44 PM
midnite rider's Avatar
Quoted: 285 Post(s)
do u have a fuel pressure gauge in your truck if not take cap off top filter have someone turn key to on and see if fuel pump is working. or install a psi tester on fuel bowl should be around 50 to 55 psi at least hope that helps. they are finnickey bitohes
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #6 of 21 Old 02-11-2014, 01:41 PM Thread Starter
7.3hotrod's Avatar
Its not getting fuel but I put fuel in the bowl so in theory it should fire right?
The Following User Says Thank You to 7.3hotrod For This Useful Post:
jamiesoncd (04-11-2014)
post #7 of 21 Old 02-11-2014, 03:11 PM
Powerstroke Techie
Lilpooh's Avatar
Here is a check list.
Troubleshooting a No-Start condition
Lilpooh is offline
post #8 of 21 Old 02-11-2014, 03:15 PM
Quoted: 285 Post(s)
you have air in lines now,it might try to fire. You need 50 psi min or u will be dry firing the injectors, not a good thing to be doing. You really need a fuel pressure gauge. Also you can disconect the fuel lines on fuel pump and blow air through them back to the tank, then try the upper cap thing again. Cycle pump 3 times. if no fuel then pump,s brobably toast. hope this helps i`ve been there myself.
-Tom
post #9 of 21 Old 02-11-2014, 04:09 PM
Blown F-150's Avatar
If you're fuel pump is gone (check all your fuses and connections first), you can save a few bucks by just buying the pump itself instead of the whole HFCM.
I was able to swap mine out with the HFCM in place, pretty quick job, but the bolts holding it in place are small so use caution.
2006 F-350
Lariat, Crew Cab 4X4
EGR Delete, K&N Intake, MBRP Exhaust, Level kit, Custom Ford Badges, Tranny/EGT/Boost/Fuel Pressure Gauges.
Gryphon FICM tuner
SCT XCal 3 with custom tunes
ScanGauge II
Updated STC fitting
High idle mod, blue spring update.
Blown F-150 is offline
post #10 of 21 Old 02-12-2014, 09:55 AM Thread Starter
7.3hotrod's Avatar
This is todays job, it has to run my 5.4 isn't going to be happy towing a 13,500 rollback.
Tags
no start
