another white smoke question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-01-2014, 06:52 AM Thread Starter
So I was backing up yesterday and it was taking a little throttle, then I noticed a fair amount of white smoke. Now when I powerbrake it I can get some white smoke, but doesnt do it under normal driving. Do u think the cooler is just starting to leak? The deltas are around 20. This is an 03 truck all stock except php 40 from ed and is running fine
2006 f 350 srw edge cts, coolant flush, stock
feedatron is offline
post #2 of 2 Old 02-11-2014, 01:41 PM
your deltas are pretty high. id check the egr valve for moisture. high deltas means restricted oil cooler which in turn makes the egr cooler leak
jeby64 is offline
