Awful gas mileage - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-31-2014, 10:49 AM Thread Starter
Awful gas mileage
I am getting awful gas mileage in my truck! Below 10mpg around town and not towing anything. The digital reading in the trucks that show the miles til empty never reads above 249 miles when I fill the truck up. Many times I do not get above 225 miles to a tank but on occasion it happens.
Truck does seem to struggle a little going up hills and I have to push the pedal down pretty good to go up them.
My truck is completely stock and has nothing added into it. I have a bully dog programmer but it has not been hooked up for almost a year
I appreciate any info in advance. Thanks
allstarlawncare is offline
post #2 of 10 Old 01-31-2014, 11:08 AM
mcdaniel1991's Avatar
Check for sticking breaks, hpo leaks, how many miles on your truck? Injectors could be plugged, are your tires at the right psi?
2006 F-250 XLT FX4 PSD 185,000 Mi
Innovative and Gearhead tunes, BPD 58v 6 Phase FICM,
Updated Blue spring, Dummy plugs and STC fitting, Straight exhaust, Zoodad, Sinister EGR/COOLER delete, Oil cooler Rerouted, Sinister Coolant Filter, Mobile 1 5w 30, Edge CTS Monitor, Isspro- FP, EGT, VDC and Coolant PSI. Soon to be under the knife for studs, lifters, rockers, pushrods and new seals.
mcdaniel1991 is offline
post #3 of 10 Old 01-31-2014, 11:10 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
problem #1, your running gas in ur 6.0L
That could be the problem
2000-7.3L is offline
post #4 of 10 Old 01-31-2014, 11:35 AM
Very helpful post...
post #5 of 10 Old 01-31-2014, 11:36 AM
2000-7.3L's Avatar
it was..................!
post #6 of 10 Old 01-31-2014, 12:27 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
A few things could contribute to low mpg such as clogged ebp tube, low ficm voltage, and a dirty turbo.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #7 of 10 Old 01-31-2014, 12:28 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Winter fuel is another mpg dropper btw.
"Pickle Monster"
EGR MIA
CCSB
FX4
The Following User Says Thank You to Ford_Fan1 For This Useful Post:
RedneckYankee (01-31-2014)
post #8 of 10 Old 01-31-2014, 01:30 PM
Heavy_GD's Avatar
Quoted: 1580 Post(s)
winter fuel and locked hubs.
GD
Heavy_GD is offline
post #9 of 10 Old 01-31-2014, 02:20 PM
kingbilly68's Avatar
Quoted: 2 Post(s)
I know mine is a 7.3, but, that's how mine acted when the icp was going bad...just a thought.
[/SIGPIC]2001 F-250 ecsb 4wd auto 150,xxx miles. 6637 factory straight pipe. Amsoil bypass system. Triple Gauge Pod.
kingbilly68 is offline
post #10 of 10 Old 01-31-2014, 02:29 PM
midnite rider's Avatar
Quoted: 285 Post(s)
when was the last time u changed air filter.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
