1st diesel, oil leak and operation questions - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-30-2014, 06:19 AM Thread Starter
Hey all, I am new to the forum and just purchased my first diesel. I purchased an 05 powerstroke with ~150k on it from an old friend of the family who passed.
The truck is in immaculate shape however it leaks oil and I cannot seem to find the source. The leak appears to be coming from the top of the motor and depending on which angle the truck is parked, gravity will make it flow to various parts of the engine and drip down.
I have powerwashed the underside of the vehicle and have been able to check the rear main, oil pan, and the bottom half of the heads. I checked the oil filter and what parts of the heads I can see from the top and all seems to fine there as well.
The leak is rather significant as I will almost always leave my mark wherever I park sometimes just a drop or two, sometimes more.
I know this is broad but any ideas? Anyone had a similar situation?
Also, when I purchased the truck and checked the oil, it was running right at the bottom of the "add" line on the dipstick. I ran up to the auto parts store and she took ~4.5 quarts I was astonished. How come when running that low on oil, my pressure gauge still sits right in the middle and my engine doesn't run hot at all?
Note** The old man who owned the truck had Ford replace the heads in 2007 on warranty. The truck has not had an EGR delete performed yet.
Thanks in advance for all of your help.
cheers,
Mark
truman1723 is offline
post #2 of 7 Old 01-30-2014, 06:50 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
A couple of things come to mind real quick...
Oil feed tube to the turbo
Oil return line from the turbo
Oil filter cap (bad o-ring)
Leaking IPR valve
Or any of the glow plug harnesses.
These would be the first place I'd look.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #3 of 7 Old 01-30-2014, 06:50 AM
SargentoPistola's Avatar
Welcome aboard. Start off with some questions for you...do you have a monitor to read all the information from the engine? Search around there are tons of good threads about monitoring the 6.0, a monitor isn't really an option for these trucks. Also what oil did you use? Just curious.
Check these out. These guys had similar issues. If you get through the stuff fuzz listed and it's still bad, it could be the bed plate, hope not though.
Oil leak
Oil leak
Hope that helps a little bit.
-Kyle-
2004 6.0 Eddie Bauer Excursion. The Man Van.
SCT w/ MPD
Edge CTS w/ EGT Probe
Banks exhaust
EGR Delete
Coolant Filter
Riffraff Boots
Stuff
1999 F-150 XLT 4.6 4x2. The Backup.
SargentoPistola is offline
post #4 of 7 Old 01-30-2014, 12:11 PM Thread Starter
Thanks for the quick responses I will check those places when I get home this evening.
As for the oil pressure and temp, how could I be 4 quarts low on oil and not be showing any signs on my gauges?
I understand the factory gauges aren't the best but there should be a little favor given low or high with that degree of fluctuation in the fill level.. right?
cheers.
post #5 of 7 Old 01-30-2014, 12:14 PM
dfuzz78's Avatar
Cuz the gauges are basically idiot lights that don't work.
The only gauges that really work on your dash are the speedo, rpms, and fuel.
The other should be ignored.
You need to get a ScanGaugeII to monitor your rig.
Denis "Lt. Sled"
dfuzz78 is offline
post #6 of 7 Old 01-30-2014, 04:57 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
The oil gauge is just a 7 psi switch. The truck takes 15 quarts of oil for a change. 4 quarts low, although bad, is not a show stopper, unless you were in an off-road position. Of course, you do run the risk of oil not continually flowing to the bearings.
The oil leak locations have been suggested, but it could also be a rear seal, or even from a seal after the previous fix.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 7 Old 01-30-2014, 09:01 PM
jake_duet's Avatar
It also could be ICP sensor causing the oil leak.
Early build 2004 Ford F-250 6.0
S&B Intake
EGR Delete Kit
4" Diamond Eye Turbo Back Straight Pipe
blue spring upgrade
updated oil cooler
Edge Insight CTS monitor
GlowShift boost, fuel psi, and oil psi gauges in pillar pods
08 tail lights, 05 headlights
Mf. Date July, 2003
"Keep on Strokinn"
jake_duet is offline
