Coolant Firestone Uses?? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-29-2014, 02:03 PM Thread Starter
OregonStrokin's Avatar
Quoted: 9 Post(s)
Recently I Had to take my truck on a 250 mile trip for work, well getting where I needed to go I noticed a coolant leak and saw the radiator was leaking where the plastic met the Aluminum, Well I dropped it off at a Firestone and they pressure tested the cooling system and found the Degas bottle was leaking as well as the Radiator. They replaced both of those parts and filled it with their coolant that they use. I flushed My system last summer and put AMSOIL Prop. Glycol coolant in there, It stated that it was compatible with any coolant on the market and wont turn to mud in the cooling system. It's been in there for a few days I have no Idea what coolant they use, but if anyone does is it bad on our 6.0 engines or is it fine?
2007 F350 CCLB Lariat 4x4. EGR delete, 4" turbo back straight pipe 5'' tip, coolant filter/CAT ELC, blue spring mod, DC Power 185 AMP Alternator,HFCM plug Upgrade, Everything else STOCK. 161k- January 2016
OregonStrokin is offline
post #2 of 11 Old 01-29-2014, 02:33 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
A firestone what? Tire shop,repair shop, tire manafaturing plant?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 11 Old 01-29-2014, 02:57 PM Thread Starter
Quoted: 9 Post(s)
A Firestone complete automotive center.
post #4 of 11 Old 01-29-2014, 03:02 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
They probably used the cheapest coolant they could find.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #5 of 11 Old 01-29-2014, 03:09 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 330 Post(s)
What color is it? Probably used a general purpose green coolant
@loxdce
LoxDiesel is offline
post #6 of 11 Old 01-29-2014, 03:29 PM Thread Starter
Quoted: 9 Post(s)
It's greenish yellow, Isn't only really worrysome if the coolant is harsh on aluminum?
post #7 of 11 Old 01-29-2014, 03:35 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Sounds like what we use at work. If it is,Its a very cheap Ford Gold.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 11 Old 01-29-2014, 04:05 PM
Quoted: 270 Post(s)
If it's the Zerex G-05 that's the exact same as Ford Gold just in a different bottle.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #9 of 11 Old 01-29-2014, 04:08 PM
As long as it is rated for diesels your good to go. Even when it's not rated for diesels I have known people to use regular antifreeze for several years without ill effects.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #10 of 11 Old 01-29-2014, 04:39 PM Thread Starter
Quoted: 9 Post(s)
ok, im just making sure its good to go, they said its a really universal anti freeze but I didnt get the brand name.
