P2286. Long crank hot or cold. Hard cold starts - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-28-2014, 05:30 PM Thread Starter
I keep getting a p 2286 on my early 04. This code comes up weekly and normally happens when under wot or when I'm trying to get the pos to accelerate in the mornings. The truck runs like crap until the coolant temp comes up and has been like this for months. It smokes white when trying to accelerate and misfires and shakes violently. New icp and pigtail last winter and I just changed the oil and all filters last week. Rotella 15w40 and motorcraft filters. It does this whether its plugged in or not. It always starts but sometimes is very stubborn when not plugged in. I need to fix this, tried trading it in for a 2012 6.7 but no one will take it in its operating condition. It took 7 attempts to start on saturday at about 15 degrees. The FICM is not the issue and tests good. This thing has never started fast and always has a long crank time hot or cold. The videos are all from saturday.
Truck startup attempt - YouTube
Truck Startup attempt 2 - YouTube
Acceleration issue - YouTube
97 f-250 HD EX.Cab Short Bed 5spd. Rosewood stage 1's, 3" downpipe, 5" exhaust, 4" lift ridin on 35's, shimmed fpr, resistor mod, Homemade air intake, Dana 60 swap, TS 6pos,
2004 F-350, Great Truck When it Runs Good
bryceheinz is offline
post #2 of 3 Old 01-28-2014, 05:52 PM
You need to have a live data log run and see what your pcm is seeing, run it until the problem occurs.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 3 Old 01-28-2014, 06:04 PM Thread Starter
Live log of what? Icp, ipr? I own a matco determinator. Buzz test and glow plug test pass with no issues. Icp at 2k rpm is 1185 actual and desire is 1156. Icp at idle is roughly 640. The problem always occurs. It does not come and go. Starting has been a problem that has gotten alot worse in the last 8 months.
