No start, ficm ect - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-28-2014, 02:27 PM Thread Starter
No start, ficm ect
Ok, so iv had a colt start issue for a while but it finally shut off after idling for about 10m and after I drove off. However, the next day it started. Took it to the dealer and they said bad ficm and 3 injectors (not sure bout injectors obviously). Sent my ficm to Ed at ficmrepair.com. I got back into town today and took the ficm up there and it wouldn't start at all. Threw a code for every injector high voltage (mech said usually its low) but it read no less than 47.8v and it's 28degs here in south Bama. Ed said check the wiring harness, I asked the mech to as I was home after the 30m drive. He hasn't called back, any ideas? The clips on th plugs r broke but they had been broke.
mastephens89 is offline
post #2 of 9 Old 01-28-2014, 05:48 PM
What mechanic/dealership are you using in south bama?
Bleehebner is offline
post #3 of 9 Old 01-28-2014, 06:29 PM Thread Starter
Chuck Stevens ford, where I bought it.
post #4 of 9 Old 01-28-2014, 07:20 PM
If the clips are broke your plug is probably not makeing a good connection.
There is a trick useing tie wraps/zip ties to hold it in poeition for a temp fix.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 9 Old 02-09-2014, 12:49 PM Thread Starter
So after sending it to Ed at ficmrepair.com, he sent it back (replaced power supply , premium w/atlas 40). Plugged it up and nothing. Let the mechanic check everything still nothing. Sent it back to Ed and he found water and coolant in it (found some before that's why he replaced the power supply). He is sent a new one will install tomorrow. My question is, no one removed the access cover and the mechs drained fluids to make sure they got it in good. How could coolant or water got back in!? Anyways, will post tomorrow.
post #6 of 9 Old 02-16-2014, 07:56 AM Thread Starter
Truck is running almost perfect, still need to take my turbo off n clean it. Getting 18.5 @75mph. Towed a john deer tractor on a double axle 24' trailer the other day was getting 15.8 @ 65mph. I'm bone stock besides the ficm and intercooler hoses.
post #7 of 9 Old 02-18-2014, 05:35 AM
Did you ever determine the cause of your FICM failure? I have a similar problem right now--0.0 volts on my BPD FICM. My truck ran fine the night before, then the next day would not start. Edge CTS showed 0.0 v; test with multimeter showed 0.0 volts. Pulled the FICM to check wiring harness connections--all seem good. No chaffing on harness either. So, my FICM (only 15 months old from BPD) seems to be toast, but I have no idea what would cause it.
ROB
2006 F350 Lariat CC LB FX4 Dually Auto 4.10
MODS:
Edge Insight CTS
SCT X4 Quicktricks Custom Tunes
KC Stage 2
MBRP 4" Turboback Straightpipe Exhaust
BPD 58v FICM, PHP Atlas 80 Tune
IPR High Flow Coolant Filter
ARP Head Studs & EGR Delete
Blue Spring
DC Power 250 Amp Alt & Big 3 Upgrade
Interstate Mega-Tron Plus 65 Batteries
42" LED Light Bar
Fleetrite ELC Coolant
IPR Remote Oil Cooler
2008 Tow Mirrors
20" Meyhem Monstir Chrome Wheels
SelahPSD is offline
post #8 of 9 Old 02-18-2014, 05:54 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Call BPD. They will treat you right.
888-967-6653.
Please
You could save the life of a sick child
NYC F-350 is offline
post #9 of 9 Old 02-18-2014, 06:04 AM
DieselFab67's Avatar
Quoted: 34 Post(s)
Give Andrew a call at 888-967-6653.
If you bought it 15 months ago, it's an earlier revision power supply. When our vendor went to machine placing (vs. hand placing) the components on the boards, we had some quality control issues. This caused poor solder joints on a few of the smaller parts. This in turn would cause the power supply to fail.
We have since changed the layout, component placement and quality control. If it turns out that you have this issue, Andrew will expedite getting you a new one under warranty.
6.0 Powerstroke issues? Go to our website for answers.
DieselFab67 is offline
