Slight surge while cruising - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-27-2014, 03:03 PM Thread Starter
I just got my injectors done last week. It helped the cold starts. But I still get some surging. I cleaned the turbo on the weekend with no change. It seems to do it under slight load like at cruising speed. I have cleaned the egr valve. new filters. Ficm is good. Replaced the ebp sensor.
A friend of mine has a OTC Genesis
My question is what should I be looking for? Keep in mind I have no idea what "good values" are. If there is a range that something should be within that would be very useful to know as we'll
Thanks in advance
Bobbie is offline
post #2 of 8 Old 01-27-2014, 07:36 PM Thread Starter
Forgot some details. It's a 2005 f250 74000 miles
I've been chasing the surging for a while it seems to happen cold and hot. I can hear the tone of the turbo change like it's hunting and if I'm accelerating the Rpms seem to go up in steps. I'll try to take a video tonight on my way home. Not sure if it can be heard.
Bobbie is offline
post #3 of 8 Old 01-27-2014, 09:01 PM Thread Starter
videos arent very good... cant hear the turbo at all but you can kinda hear the rpm stepping
Bobbie is offline
post #4 of 8 Old 01-28-2014, 05:49 PM Thread Starter
Are there any sensors I should look at specifically?
Bobbie is offline
post #5 of 8 Old 01-28-2014, 06:08 PM
As far as a sensor values list there is a member named bismic who has produced a rather extensive list gleaned from varieous sources run a search for his post, rather long several pages of post but worth every byte.
This will be someting that you will need to data log to catch it in the act so to speak.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #6 of 8 Old 01-28-2014, 06:11 PM Thread Starter
Ok thanks I'll try to find it. Thanks
Bobbie is offline
post #7 of 8 Old 01-28-2014, 07:20 PM
sprksonu's Avatar
Maybe the ficm wire harness? Mine was bad and was doing the similar thing. Ford has a updated one now that is re-routed so it doesn't rub the wires through. Also the female ends that go on the injector harness stretches out over time from heating and cooling down and being disconnected many times.
Sent from a phone I found at the bar
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
The Following User Says Thank You to sprksonu For This Useful Post:
RafterQ (06-23-2014)
post #8 of 8 Old 01-29-2014, 03:26 PM Thread Starter
I looked for his thread and didn't find it. Do you know the title or something I can search that would lead me to it? Was it an old thread? The results only went back to 2012
Thanks
Bobbie is offline
