another crank and no start problem - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-26-2014, 11:11 AM Thread Starter
First I'd like to say hi, and thanks for any thoughts and input. A lil history on the truck it, its a 07 f250 with 115k miles. regular maintenance, new batteries (1 month ago), and new fuel system upgraded (10 months ago) other then that stock.
Well to get down to it, earlier this week it wouldn't start at the end of the day, so I get a ride home. The next morning I show up and it fires right up. No codes
2 days later it does the same thing crank no start, fries right up the next day.
I'm a nubie but Ive been lurking on this site reading everything. So I did try discoing the ICP when it happened no change
The ICP reads 580 the ficm is sitting at 48v on idle and 46.5 on crank the IPR is at 14% with key on and jumps to 30% on start up, idling it sits at 23%
inj pulse width bounce between .99 -1.11 at idle
oh and 45 psi at fuel bowl, with 14.0v battery on idle dropping to 11.9 on crank.
Any thoughts
fu6.0 is offline
post #2 of 16 Old 01-27-2014, 04:39 AM
Mine has the same problem. I haven't done the troubleshooting that you have completed. It started one day...runs fine. I go to pick up a mattress and the truck just wont start in the parking lot. I had it towed to my tech (Bob Turner in W. Bridgewater, MA) for repair. He is very talented and fair. I should hear something this week. I will let you know since the info might help you out.
jdrcapecod is offline
post #3 of 16 Old 01-27-2014, 08:46 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
It is not starting when engine is hot (right) ?
Check your:
ICP
IPR
When you go to start it when hot. If it's a HPO leak you will see high IPR% and under 500 on the ICP.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #4 of 16 Old 01-27-2014, 08:56 AM Thread Starter
Those numbers were when it was running hot (drove it home) but when it hasnt started it hadnt run for a couple of hours, last time it didnt start ipr stayed at 14% and the icp spiked to about 1100
thanks jdr let me know what you find out
fu6.0 is offline
post #5 of 16 Old 01-27-2014, 04:24 PM Thread Starter
Ok talked to a mechanic today he said it might be the cam position seensor, and crank position sensor, any thoughts?
fu6.0 is offline
post #6 of 16 Old 01-27-2014, 05:09 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
I think you have a hpop problem either icp or ipr. I just started mine with the key in the on position the ipr read 17% but once I tried to start it immediately went to 47% then in three seconds it started. Either your ipr is bad or maybe the screen has some trash on it. To me a crank position sensor would throw a code.
I believe when you have a hpop leak your ipr % increases over 50% because the pump is trying to supply the necessary pressure to fire the injectors.
I would pull the ipr and inspect the o ring and screen for damage.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #7 of 16 Old 01-27-2014, 08:02 PM
Quoted: 9 Post(s)
Just had some of the same symptoms myself. Son calls and says truck won't start. It had died a couple of times the weeks before but started right back up. When it wouldn't start, everything looked fine on the AE. 1800 PSI starting, 48V on ficm etc.
We did notice that when you turn on the key we did not hear the buzz test being completed. Are you hearing the buzz test?
I think we have fixed it because we have not had any problems for the last few days. We determined it might be the FICM plug locks were broke and one of the plugs was not making good contact. It was strange that the ficm looked good on the AE but was not operating the injectors. At any rate, I put a piece of heater hose underneath the plugs and tightened down the ficm and that will hold the plugs up in there. The key was that we did not hear the injectors cycling at Key on.
divotf15 is offline
post #8 of 16 Old 01-28-2014, 09:48 AM Thread Starter
Im hearing the buzz from the injectors but I have not had anyone do the buzz test on individual injectors
fu6.0 is offline
post #9 of 16 Old 01-28-2014, 04:02 PM
Quoted: 9 Post(s)
If you are hearing the buzzing of the injectors then it is not the same problem I had. They were totally dead at Key On.
divotf15 is offline
post #10 of 16 Old 01-29-2014, 07:47 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
Could be a bad HPOP
AshevilleEngine.com is offline
