Welp, Did the coolant pressure test... - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 36 Old 01-25-2014, 02:56 PM Thread Starter
I ended up with a 60psi gauge after visiting 4 stores it's the smallest PSI I could find in stock...
I made it with 8ft of 3/8" hose, a 3way T and a few fittings to make the gauge adapt to 3/8". Overall about 34.00.
I ran 3 test with engine warm and pressure released. Then flooring the engine up a steep grade.
All three trips my gauge hit about 8-10psi, when I let off at the top of the grade and to slow down before getting a ticket, it would quickly jump to 10-12.
The pressure was staying at 10-12 until I romped on it again and even on level surface, quickly bounced to 16...
Each time, it stayed at 16 until I released the pressure at the cap, I even heard gurgling once while releasing pressure.
So I was surprised that getting up the steep hill flooring it, it did not jump to 16, but I did eventually get the gauge to quickly hit 16... So I guess this confirms HG leak. I was in stock tune and notice some puking just running 30 mile round trip to get supplies for this...
EOT Hit 199, ECT 193
TxOutlaw is offline
post #2 of 36 Old 01-25-2014, 03:56 PM
JustinOOO9's Avatar
Quoted: 574 Post(s)
Garage
so you have been loosing coolant lately?
also where have you been filling the degas bottle to? it should NOT be at the full line or most will puke under extreme loads.
when my HG were bad it would puke going 80mph during WOT runs and I would hit 20psi and build pressure really fast... if your holding 16 psi it sounds good to me man. how much did it puke the time you noticed it?
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s, JW Vbody.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 36 Old 01-25-2014, 04:05 PM Thread Starter
I have been puking just a bit when I really push the truck or have extreme street tune on. Not a huge mess at all.
I keep it just under the min line and have a new cap. I have been using 50/50 coolant mix but not sure what the previous owner had in it but he had it flushed about 30k ago. I may flush again and put ELC in.
Would the system not climb over 16 due to the cap releasing pressure?
Thanks for the help!
TxOutlaw is offline
post #4 of 36 Old 01-25-2014, 04:11 PM
mcdaniel1991's Avatar
Yes the cap releases pressure at 16psi, I can get mine up to 17 but not with the stock tune. Coolant pressure should be directly related to Temp NOT boost or engine load. If you still have and EGR it could be leaking but you have a leak somewhere. My truck is doing the exact same thing. I just pulled a 7 percent grade and my psi jumped to 12 with the stock file loaded.
mcdaniel1991 is offline
The Following User Says Thank You to mcdaniel1991 For This Useful Post:
RedneckYankee (01-25-2014)
post #5 of 36 Old 01-25-2014, 04:18 PM
JustinOOO9's Avatar
Quoted: 574 Post(s)
Garage
do you have a monitor to check your engine coolant temp, vs engine oil temp difference?
Justin,
post #6 of 36 Old 01-25-2014, 04:22 PM
Originally Posted by TxOutlaw View Post
......EOT Hit 199, ECT 193......
From his original post
post #7 of 36 Old 01-25-2014, 04:27 PM
information regurgitator
NYC F-350's Avatar
Quoted: 53 Post(s)
Me too.
10 char min
Please
You could save the life of a sick child
NYC F-350 is offline
post #8 of 36 Old 01-25-2014, 04:27 PM
RedneckYankee's Avatar
Sounds like what my 05 Ex was doing. System pressure would be about 10-12 PSI and as soon as I started building boost the gauge would spike to 16-17 PSI. When the shop pulled the heads the passenger head gasket was just starting to let loose. Got lucky no damage to heads. Now she is studded and completely bullet proofed.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #9 of 36 Old 01-25-2014, 04:28 PM
NYC F-350's Avatar
Quoted: 53 Post(s)
Are you slowly building up to 16, or is it shooting right to 16? This is the difference...
Please
post #10 of 36 Old 01-25-2014, 04:34 PM
With the coolant pressure released at operating temps just pulling a hill it should not get to 16 psi. If its directly related to cylinder pressure it would have to be a head gasket or EGR.
