fragile starter solenoid terminals - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-25-2014, 01:57 AM Thread Starter
Maybe I'm used to starter terminals being more durable, its 10 degrees out and I'm putting in a new starter, 2004 6.0, the old cable end rotted and broke off so I put a new one on. Normally I lower the starter and detach the cables but the main batt cable snapped off. I have a bunch of hd crimp ends, so carefully cut off the old connector, little heat to melt the solder, solder on a new one and crimp it tight before covering it with epoxy heat shrink.
Had to bend the terminal end to get it to align with the starter, and I start spinning the nut on, new started bolted in place. I'm using a stubby 3/8 ratchet and feeling the cable, twist the nut, adjust the cable repeat, I've only got finger pressure on the ratchet when it pulls the terminal out of the solenoid... WTF, The old starter did this when I went to remove the cable end.
I'm shocked that they're so fragile and not a long enough terminal to get two wrenches on it.
Mostly just venting, now see if I can find a solenoid. this one has the tips of the screws soldered but not a big deal to remove them.
fast_st is offline
post #2 of 9 Old 01-25-2014, 06:23 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
Is it a Ford starter?
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 9 Old 01-25-2014, 10:22 AM Thread Starter
Ford guy says the terminals are pretty fragile. it turns out the screws were not soldered in. also a heavy-duty ring terminal needs to be trimmed down a little in order to fit I'll pick up another solenoid on eBay
fast_st is offline
post #4 of 9 Old 01-31-2014, 08:10 AM Thread Starter
Shaving just 020 off the outer radius of a typical 2/0 3/8 crimp terminal gives enough room for everything to clamp down stress free.
fast_st is offline
post #5 of 9 Old 01-31-2014, 02:41 PM
The biggest problem I find is the thin back up nut loosens or is often missing and the whole t-bolt tries to turn in the bakealite and it breaks.
I don,t see where they think they are saveing that much money makeing that nut soo thin LOL.
Yes finding a wrench that will fit is near impossible. I use a half of an old 90 deg. box end that I ground down on the inside surface till it is only about 1/4 in.
thick. I do not use it on anything else it is not strong enough.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #6 of 9 Old 01-31-2014, 02:46 PM
ZMANN's Avatar
Quoted: 1794 Post(s)
i just had the starter out and didn't notice any issues then again you had a terminal contact issue didn't you ? assuming that's is why you put another one on ??
that terminal could have had excessive heat due to a poor connection and compromised the housing
the solenoid reminded me of a chevy Small block solenoid the one that is on a billion vehicles
as far as wrenches I had no problem getting a deep socket 1/4 drive on both of the terminal nuts
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #7 of 9 Old 02-01-2014, 04:54 AM Thread Starter
My old one nor the new one had a backup nut, just the one nut and a pretty short stud to clamp it all down on. Yes indeed, after removing the starter I found that the battery cable end was about broken off, so using a wizzer wheel I cut the terminal, pryed and unsoldered it apart after cutting off the heat shrink. Applied a new crimp terminal, standard 1/0 size as it would just fit over the cable. crimped/soldered and heat shrunk the new terminal onto the cable then destroyed a brand new starter with it.
I opted to toss a new starter into it because I had the non starting issue, power getting to the solenoid, solenoid clicking, voltage reading at the starter housing to ground showing less than 1/10 volt, 12.8 at the battery terminal and zip to the starter terminal. So the solenoid was toast.
fast_st is offline
post #8 of 9 Old 02-01-2014, 04:59 AM
ZMANN's Avatar
whos " new" starter ?
i don't remember a back up nut on the stud like a chebby would have ?
seems like it would be required but i didn't look
my starter has 100,000 miles on it ans I dropped it to access another item it looked good so I cleaned it and reinstalled it
the only thing i hated was that back bolt LOL
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #9 of 9 Old 02-01-2014, 05:25 AM Thread Starter
New from my local alternator/starter shop, I take all the fire truck starters and alternators to them, and they'll do anything you want to a starter or alternator from economy repair to full rebuild to just give you another one. Sadly they started closing up on weekends so I put myself in a big bind with the truck dead in the middle of the driveway.
fast_st is offline
