sudden oil pressure drop - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-24-2014, 09:08 PM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
Driving home from work tonight heading down the highway at 60mph. I let off the pedal and oil pressure (dummy gauge) dropped to nothing. Truck never died after about 10sec it jumped right back up. Is it the sensor did my oil cool blow. Temps were normal range when parked. The oil pressure sensor is oily. Then anything I could be missing?
04fording is offline
post #2 of 8 Old 01-25-2014, 06:26 AM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
If the oil pressure switch is oily it is leaking. It takes almost nothing for oil to get in the lone pin and lose contact. You should look into replacing the switch and connector. Usually when the connector is contaminated it can still cause problems even after a new switch is installed
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 8 Old 01-25-2014, 06:42 AM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
What about cleaning the connector with contact cleaner?
post #4 of 8 Old 01-27-2014, 09:19 AM
mrenn's Avatar
Quoted: 3 Post(s)
It seems to be a common problem on the 6.0.Mine does the same thing even after a brand new one was installed.Still trying to find the root of the problem and most likely it is a leak somewhere in the system cause my truck still has starting issues.If you replace it and it does the same thing then you know there is a problem elsewhere in the oil system.
ARP,EGR Delete,SCT,4.56 gears,powermax,Banks Techni-cooler,Adrenalin HPOP,Donohoe springs,fox shocks,airbags,blue spring,38x15.5 M. Thompson's,4 10's,2 tv's,playstation,amp-steps,2013 tailgate,edge cts
2016 Lariat 6.7.
mrenn is offline
post #5 of 8 Old 01-27-2014, 01:38 PM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
Well it doesn't have any starting issues. And I never have to add oil between changes I have a small leak from my turbo drain tube have the new one just waiting on my oil cooler before I replace it. And it hasn't happened since then. So hoping it may have been a fluke thing.
post #6 of 8 Old 01-27-2014, 01:50 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 369 Post(s)
My 05's been doing it for over a year now. I just haven't gotten around to fixing it.
@loxdce
LoxDiesel is offline
post #7 of 8 Old 01-27-2014, 02:28 PM
midnite rider's Avatar
Quoted: 285 Post(s)
could be electrical fart caused by moisture, cold weather who no`s, a mechanical gauge takes out the doubt jmo
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #8 of 8 Old 01-27-2014, 11:08 PM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
Well when I'm off work she's getting an oil change tstat done I'll pull that sensor out hook up a mechanical gauge and see what I got
