Puking Coolant/ Heater Barley works - Ford Powerstroke Diesel Forum
post #1 of 31 Old 01-23-2014, 05:59 PM Thread Starter
OregonStrokin's Avatar
Quoted: 9 Post(s)
Hi all Im new here and Have been reading threads for the past few hours and cant seem to find a list of answers. I have a 04 f250 Its Studded and those were put on around 90k miles ago (180k on the truck), EGR Delete, Has a coolant filter I installed AFTER flushing the cooling system. Im still puking coolant out the Degas bottle and the Heater hardly works. When Im running the truck around town i'll monitor it and it'll settle at around 176 degrees and the oil temp will be around 184 or so. Its rarely get past 10 degrees of each other So im thinking that rules out a bad Oil cooler. I can really really get on it (Running a SCT Extreme street tune) and the truck wont get hot. The truck actually cools off at while Idling. So to put in a list here is what Im experiencing
-Heater cools off at Idle
-Only warms up when I rev it up
-EOT and ECT are within 10 degrees of each other when I reach Operating temps
-I filled the DEGAS Bottle today and that Kinda helped the heater situation, even though it took around a gallon of fluid it was still puking coolant before then.
-I over filled the DEGAS a little today so some puking is expected.
Could it be something as simple as the DEGAS bottle cap? I put a new For one on there around 6 months ago and when I go to take it off, even if it's cooled off for a few hours it still lets off a bit of pressure and whistles at me.
Or could it be something as air in the system that causing it to burp and the heater to not work correctly?
Im sorry if when I typed this out its difficult to follow.
PS-
-I have the stock DEGAS bottle could I just have the coolant way over filled? even though I added nearly a gallon of coolant it's never over heated, but the heater not workin is something new that's seem to have happened.
Thanks in advance for the help guys, ive been thinkin about this all day lol.
OregonStrokin is offline
post #2 of 31 Old 01-23-2014, 06:34 PM
broncomitch's Avatar
My wife's explorer has the same systems...people are telling me it's the head gasket's..
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #3 of 31 Old 01-23-2014, 06:43 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
Here is some info.
Troubleshooting coolant loss (white residue around cooling system components(degas))
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 31 Old 01-23-2014, 06:59 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
That's how it happened to my truck...
First puking...
Then puking and heat loss...
Finally head gasket failed, hydrolocking the engine...
You can choose to replace the head gaskets now and stud the truck, or you can put it off until it fails, possibly stranding you when you don't need it.
I'd start saving for the head gasket job...
I don't know where you are in Oregon, but the shop to go to is Vision Diesel Performance. (503) 487-6074
Give Derek or Curtis a call and they will take care of you, honestly and fairly.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #5 of 31 Old 01-23-2014, 10:22 PM Thread Starter
Quoted: 9 Post(s)
I heave Head Studs on the truck already, I know when I first Got The Truck it had a cracked EGR cooler but I deleted that all together rather quickly. Could it be possible I Stretched the Head Studs?
2007 F350 CCLB Lariat 4x4. EGR delete, 4" turbo back straight pipe 5'' tip, coolant filter/CAT ELC, blue spring mod, DC Power 185 AMP Alternator,HFCM plug Upgrade, Everything else STOCK. 161k- January 2016
post #6 of 31 Old 01-23-2014, 10:36 PM
4u2nvme's Avatar
What type of head bolts. ARP? If you torqued to specs I highly doubt you stretched them. I see you have a tuner, do you run really rad tunes? The heads when the studs done, did you get them removed and tested? Please say you used the ford head gaskets and did not cheap out on the black onyx ones.... They are very unreliable. I did read in here somewhere twice about heat problems coming down to head gaskets, with your puking does sound like heads again.
To be sure search hero tester I think on here and properly check the pressure in your cooling system while warm and u dersome heavy load..... You tube it also.. That give you the for sure answer.
Ain't logical. Cuttin' on his own face, rapin' and murdering - Hell, I'll kill a man in a fair fight... or if I think he's gonna start a fair fight, or if he bothers me, or if there's a woman, or if I'm gettin' paid - mostly only when I'm gettin' paid. But these Reavers... last ten years they show up like the bogeyman from stories. Eating people alive? Where's that get fun?
4u2nvme is offline
post #7 of 31 Old 01-23-2014, 11:32 PM Thread Starter
Quoted: 9 Post(s)
The head were done under warranty by Ford, at around 90k miles (180K on truck now) Im assuming they used ARP and Ford gaskets. I found that out from the owner two times before me.
I dont run really rad tunes, I dont get on it much unless im merging with traffic or feeling like burning the road up and trust me there's no lack of power!
Im wondering could it be something as simple as a clogged Heater core and Over Filled DEGAS bottle?
I will test The cooling system pressure after work today, I'll also emory cloth the degas bottle and get a new cap while im there, and check for leaks.. in the engine bay around the coolant filter I remember hearing a hissing sound, I wont if one one he shut off valves has a leak on it? Would that make it suck air?
post #8 of 31 Old 01-24-2014, 07:09 AM
4u2nvme's Avatar
You may want to check to see if Ford used ARP head studs. They most likly would not have used them when they did the work unless the person doing it paid the extra. You can tell if they were used by looking at this link.
ARP Head Bolt Photo usage Link
It explains how to tell if they were used. If they were not used and your using a tuner its a good chance they were stretched. The inline pressure gauge on the cooling system should let you know what is what with those heads. Good luck and I hope it is just something plugged, but does not sound great.
Good Idea on the cap if its the original cap, as that can be the Release Pin that starts the whole Grenade process of the heads counting down when it fails.
-NV
4u2nvme is offline
post #9 of 31 Old 01-24-2014, 10:20 AM Thread Starter
Quoted: 9 Post(s)
I can confirm its Studded here's a picture
Also I bought a new cap it looks extremely different than the one I have on there. Also maybe when the shop flushed my coolant last summer they didnt turn the head on, so the crud in the heater core may just be blocking the coolants path through until I rev it up. Im replacing the cap, and the heater core today. We'll see if that's any luck. the more I think about it, the more I think (HOPE!!! lol) it is.
post #10 of 31 Old 01-24-2014, 10:27 AM Thread Starter
Quoted: 9 Post(s)
Sorry, heres the photo of the stud,
Puking Coolant/ Heater Barley works-6.0-head-stud.jpg
