Engine no start (took 3 tries to start it) - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-23-2014, 11:54 AM Thread Starter
Quoted: 4 Post(s)
I went go somewhere today in my 2004. I get in the truck, wait for glow plugs and then I try starting it and it didn't. I tried again, nothing. Well the next time as soon as I began cranking it fired right up. However my scangauge didn't load at all so I was like forget it. I drive to where I need to go (ran great, no smoke or loss of power) and as soon as I get there, I turn off the truck and restart it and the scangauge finally begins working and all reads normal (FICM, icp, etc.) After all that it ran fine and started fine but I was kind of confused as to what causes my truck to do that. Wasn't too cold 54 degrees with rev x in oil and I've started it in much colder. And I had a no start issue awhile back and it was wiring and cam sensor and ford fixed it no issues with truck since.
Anyone know what could be the problem or how I can fix it?
Also fuel pump and injectors have 12k miles on them and I doubt that was the case.
joejack6.0 is offline
post #2 of 3 Old 01-23-2014, 06:46 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
Some info to check on or monitor.
http://www.powerstrokedoctor.com/troubleshooting/ford
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is online now
post #3 of 3 Old 01-23-2014, 07:28 PM Thread Starter
Quoted: 4 Post(s)
thanks that was actually quite helpful!
