Cold start always, warm starts.....usually? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-22-2014, 08:35 PM Thread Starter
Well as indicated in the title, I've got an intermittent problem with my [2005 6.0 - 57,000mi]. 3 times now
September - Started truck numerous times all afternoon, driving around farm, pulled gooseneck 15km to town, stopped off at the bank for 15 minutes with truck off, came back truck won't start, just turns over and over and over and over, no fire. Mechanic friend from local Dodge dealer swung by with his computer, wasn't building pressure. 5pm. Called a different friend, got dad to borrow his Dodge, met me at the truck at 8pm, fully expecting to tow my truck out from under my gooseneck. Truck started like a champ (8pm). Unhooked trailer, trailer to Dodge, dropped my truck off at the mechanic (20km away, drove it like it was stolen to try to heat it up), shut off truck and restarted it flawlessly 5 times at mechanics. Left it with him, he replaced a ??regulator screen?? which was torn.
December 1st - Truck was parked for several hours out in the cold, drove through the city and stopped at a fast food joint, turned truck off in the drive through (the lady in the intercom box told me to), ordered, truck wouldn't start. Employees of restaurant and myself pushed me out of the drivethrough lane. 20 minutes later truck fired up perfectly. Drove home, parked at 2am in the garage, by 7am it started perfectly.
January 22nd - Drove truck 70km, shut it off for 10 minutes, drove truck 5km, shut it off for 10 minutes, truck would not start. Would not start from 3pm until 7pm. 7pm started perfectly.
Sometimes the truck takes a long time to fire (10 seconds of cranking?), usually if you've just shut it off within the last 5 minutes, but otherwise it's perfect.
Mechanic basically wants me to leave it with him, he will drive it around until it happens to him.
Help?
Thanks,
-Josh
Current Fords:
1978 F150 XLT RCSB
2000 F150 Lariat ECSB (5.4)
2004 F150 Lariat CCSB (5.4)
2005 F350 Harley CCSB (6.0)
2006 F250 XL CCLB (5.4)
2014 F350 Platinum CCSB (6.7)
JoshA is offline
post #2 of 3 Old 01-22-2014, 08:52 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Sounds like the common "no start when hot", you have a leak in the HPOP system, usually for the 05 it's the STC fitting and/or stand pipes and/or dummy plugs. If your digging in to replace one of these part, replace them all.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 3 Old 01-23-2014, 07:27 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
^^^ This. However, there are other reasons for no pressure that are from other systems. Hopefully it will happen soon with your mechanic at the wheel. Of course, he could have it a long time before it shows up again!
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
