Possible y pipe bad and wierd exhaust tone change... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-22-2014, 07:01 PM Thread Starter
Just like the the question states, I think I found the rattle that sounds like bearings in a tin can when idling in drive or driving at any mph. I now have a turbo whistle that can be heard over the heater fan inside as well as the radio when driving on the high way at 50-60 mph. So at this point I am assumig that the y pipe has cracked. I have no DTCs showing on the Scanguage and everything shows okay on the Torque App. I also noticed while waiting at a stop light in idle that the exhaust tone changed 2 times which makes me more certain that the y pipe is a goner. Any thoughts on a replacement and one that does not require an EGR delete (just replaced the EGR 2 weeks ago for $150.00 and don't want to lose that money).
rhillman75 is offline
post #2 of 5 Old 01-23-2014, 09:05 PM Thread Starter
What... did I stump someone? Can someone at least give an idea of why the exhaust tone would change tone at a stop light or waiting at a stop sign. I think the high pitch whistle im hearing from the turbo is pointing towards the y-pipe.
post #3 of 5 Old 01-24-2014, 12:13 AM
Sounds like your on the right track. If your hearing it change tones at idle I would crawl underneath with it running and listen.
Are ya sure the whistle isn't coming from your cap leaking pressure and causing a "tea kettle" pressure bleed off sound. I would look for coolant/white residue around degas bottle cap and check coolant level.
FawlGuy is offline
post #4 of 5 Old 02-07-2014, 05:17 AM
Quoted: 4 Post(s)
Mine has been doing the whistle/whine thing at 60 MPH and the rattly sound at idle, too. I narrowed down the rattle to the exhaust, as it stops if I put my foot on the tailpipe to keep it from moving. I suspect the cat may be failing inside.
tesmith66 is offline
post #5 of 5 Old 02-07-2014, 07:18 AM
Quoted: 2 Post(s)
Yep, that's what mine sounded like when the stock flex sections blew out.
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
