What could it be now? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-22-2014, 02:55 PM Thread Starter
Diverdan's Avatar
This just started happening. When running down the road, between 50-70 mph, when I give it some throttle, the truck sputters and seems like it is missing. I get off the gas and it stops, then I get back on the throttle and it sometime it will run normal and sometimes it will sputter again. I get no engine light. Any ideas?
2004 F-250 Harley Davidson Edition. 117000 miles on it.
Diverdan is offline
post #2 of 2 Old 01-22-2014, 07:48 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
Need info. Fuel psi, ICP, IPR, FICMv. Read codes with a good OBDII scanner.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
