need help ASAP motor removal - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-21-2014, 05:53 PM Thread Starter
I'm stuck removing the engine. I cannot get the engine out and the flywheel is coming with the motor I can't find any type of diy or writeup. oil pan is not clearing the cross member engine dosnt go high enough up pipe is in the way. Engine is midair and need to get it pulled today. Everything is disconnected.
6.OPowerstroke is offline
post #2 of 5 Old 01-21-2014, 06:32 PM
The 6.0 engine is designed to be pulled up level and removed out of the front of the truck.
All coolers and front clip are to be removed as well as the upper crossmember support. When hung correctly you merely need to lift to clear the lower crossmember by only a few inches and then it will walk right out.
If the tranny isn't seperateing ya missed a bolt or nut on the flex-plate or flywheel. They useually seperate pretty easy but sometimes a judicious whack with a large hammer is required.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 5 Old 01-21-2014, 06:38 PM
gotta_gofast's Avatar
Quoted: 60 Post(s)
Dannyboy is right, the motor gets lifted up enough to clear the crossmember then slid forward out the front of the truck, you can even leave the hood on. The flexplate should be attached to the engine. You need to unbolt the torque converter from the flexplate and if required take a dead blow and tap around the bellhousing to release the seal. If you left the up pipes on, you should remove them.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #4 of 5 Old 01-21-2014, 06:45 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
The flywheel stays with the engine, the torque converter stays with the transmission. You need to pull/drop the transmission rearward and ensure enough of the front end is dismantled. Use a rachet strap to support the transmission. The bumper can usually stay on, but it is only a few bolts.
The engine goes forward and up. Pull the engine?
A pic from Laferty's repair.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 5 Old 01-21-2014, 10:29 PM Thread Starter
Thanks guys got the sucker out forgot a bolt on the flywheel and up pipe was in the way, thanks for the quick help. Cheers
