Base oil pressure question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-21-2014, 12:56 PM Thread Starter
A friend is working on a 05 f-450.It stalled and will not start. He replaced the HPOP because there was no oil pressure. Still no oil pressure. Checked the base oil pressure at sending unit port. Nothing! But it will fill the oil filter housing.
So my question is why is there enough pressure to fill filter housing but will not push oil out of the sending unit port?
Thanks in advance
2005 F-350 King Ranch CC LB DRW 4X4
Edge Insight
MBRP 4" exhaust straight pipe
Sinister EGR delete
Zoodad mod
SCT tuner X3/ Gearheads tunes
Coolant filter
Blue FPR spring kit
Glowshift Fuel Pressure Gauge
jlfq2 is offline
post #2 of 6 Old 01-23-2014, 04:18 AM
Was the oil filter in the housing when they were trying to check pressure?
Diesel Equipment service manager lead technician
jpott62 is offline
post #3 of 6 Old 01-23-2014, 06:20 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
^^^ That is the $64,000 question.... Are there any members that actually remember this question or even the name of Roy Rogers' horse?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 6 Old 01-23-2014, 02:40 PM
Bad low pressure oil pump...
If a power stroke 6.0L doesn't has HPO pressure, first check the LPO.
You need at least 60PSI in the LPO for the HPOP to start pumping to the HPO system.
Also you could have a broken by-pass valve, wich is located just down the LPOP. You can fix this by adding a coin before the spring, just over the nut that is an allen drive.
JorgeCanek is offline
post #5 of 6 Old 01-23-2014, 05:55 PM Thread Starter
Yes filter was installed.
I was thinking he should just go ahead and replace the LPOP.
Edge Insight
Sinister EGR delete
Zoodad mod
Coolant filter
Blue FPR spring kit
jlfq2 is offline
post #6 of 6 Old 01-23-2014, 06:57 PM
Need to pull pump apart and see if it's damaged. If it looks like needles went through it there will be a lot more work to follow. The truck I bought had this problem. Lifter went bad and tore up the cam and oil pump. It also ruins the front engine cover.
jpott62 is offline
