Cuts Off - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-19-2014, 08:26 PM Thread Starter
Cuts Off
2004 F250 6.0L purchased 2 months ago. 145k miles.
At high speeds, truck starts to "choke" or "starve" for fuel. When you slow down, the engine just cuts off. This happened a few months ago and I replaced the fuel filters with no problems since.
4,000 miles later it is doing it again. I wouldn't think the filters would be bad again? I do know it needs an injector on the 7th cylinder but do y'all think I need a fuel pump too?
cduggan3 is offline
post #2 of 6 Old 01-20-2014, 04:24 AM
midnite rider's Avatar
Quoted: 285 Post(s)
Can u monitor your fuel pressure. Could be the pump
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #3 of 6 Old 01-20-2014, 04:50 AM
nibesdiesel's Avatar
Could be the hpop stc fitting if that's not updated
nibesdiesel is offline
post #4 of 6 Old 01-21-2014, 05:46 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 350 Post(s)
04 has no STC. Id be more inclined to see what your fuel pressure is with KOEO. I had a truck that would run on 8psi of fuel pressure. Dunno how. It would occasionally shutdown. Good Luck
@loxdce
LoxDiesel is offline
post #5 of 6 Old 01-22-2014, 08:31 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Cuts Off
If it's a late 04, check the throttle body butterfly for proper operation or coked with soot.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 6 Old 01-22-2014, 08:35 PM
LoxDiesel's Avatar
Quoted: 350 Post(s)
Every truck I work on I remove the butterfly.
@loxdce
