Possible Boost leak?? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-19-2014, 09:50 AM Thread Starter
Mtsnowking's Avatar
Okay so i have a 04 6.0 with 5'' TB exhaust and the H&S minimax. when i get to pushing a lot of boost (like upwards of 20lbs or more) when the torque converter locks its like the truck falls on its face and has no power then just belches black smoke until i let off the throttle and step back into it, then you can hear the turbo spool back up? AHH ive been trying to figure this out for quite awhile now. i took off the intercooler boots and put them on with hairspray and and i think it may have helped a little bit but not much.
Mtsnowking is offline
post #2 of 5 Old 01-19-2014, 01:50 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Does the truck do this when running the stock tuning?
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 5 Old 01-22-2014, 10:29 AM Thread Starter
Mtsnowking's Avatar
No which has me stumped, the truck doesn't do it in stock at all. i uninstalled the h&s tune and returned the truck to stock and stood on it getting onto the freeway and i pushed 24 lbs boost which seems normal? i reinstalled the tune and put it on performance (+120hp) and like always when the torque converter locked the truck fell on its face and had ZERO power until i let off then the turbo re-spooled and is fine
post #4 of 5 Old 01-22-2014, 11:11 AM Thread Starter
Mtsnowking's Avatar
Ill also add that when i have no boost and i get into the throttle my EGT's go through the roof. Not sure if these are related, but in town my EOT and ECT are about the same (185-187) the minute i get on the highway im around 200-206 EOT and 185-190 ECT empty. with two sleds on the deck my EOT has been 220 before and my ECT around 200-208. the delta never exceeds 20*. if i pull a big hill where im pushing alot of boost on the highway once i reach the top of the hill i can feel the engine miss ONCE (all it sounds like is the turbo respools)? or all the sudden ill have no power and once i let off the throttle and get back into it the turbo respools and is fine.
2004 F-250
8'' Lift 38x13.5 Toyo Mt's
Arp Head Studs, EGR Delete
H&S Mini Max
5'' Exhaust
post #5 of 5 Old 01-22-2014, 08:15 PM
Powerstroke Techie
Lilpooh's Avatar
I would contact H&S to see if it's a tuning/software issue first.
Lilpooh is offline
