Weird Injector issues - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-19-2014, 09:20 AM Thread Starter
I have a 2005 6.0 cc with studs, sct, bulletproofed, coolant filter and running 5w-40 with archoil and fresh fuel filters every other oil change.
Now, as to the problem my truck was starting to act up a little bit on start up so i sent the ficm off to FICMrepair.com and got back one with atlas 40 cause lets face it who doesn't want more power!!! while i was waiting on the FICM i was on my way to work and my truck started bucking and jerking pulling a hill in overdrive slowed down and truck went back to normal. Pulled codes for cylinder contribution on 2,4 and 5 cleared codes and truck ran great for 4 days after. I recieved my Ficm so i Installed it and right away it showed cyl #1 contribution/balance with a bad miss so i R&R cyl 1 injector with a reman from ford put it back together and right away it shows Cyl #5 contribution/balance p0275 with exact same feel / bucking under load in overdrive. Is there something im missing or should i just R&R the whole bank of injectors but i dont understand why if #5 was weak why it wont show me before i replaced #1? Could this be a wire issue. it is a warm & cold issue i can feel the miss all the time at about 2200rpm but under load in overdrive it is the worst. Any help is appreiciated.
2005 F350 CCSB Lariat
6.0
Cooper AT3 270/70/18
ARP and oems
Bulletproof EGR cooler (deleted)
Bulletproof Oil Cooler
SCT SF3 w/vivs tunes
08 tailgate and lights
6K HID in Headlights and Fogs
Reese Gooseneck and Laverne Bumper
60 gal Aux/tool
Pioneer DVD-4300
bulldog55964 is offline
post #2 of 3 Old 01-19-2014, 11:27 AM
When problems move from cylinder to cylinder I have useually found it to be wireing or plug-in issues.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 3 Old 01-19-2014, 12:19 PM Thread Starter
its weird tho cause i thought that too but shouldn't i get an injector circuit code alongside my contribution code
6.0
ARP and oems
60 gal Aux/tool
Pioneer DVD-4300
