Keeps hydrolocking - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-18-2014, 08:42 PM Thread Starter
dkapp0802's Avatar
Keeps hydrolocking
Just as the title says the motor keeps hydro locking with fuel and oil. I've revealed the injectors and it keeps happening. I'm thinking about shotguning a set of injecotrs to see what happens.
Any suggestions before I do
dkapp0802 is offline
post #2 of 7 Old 01-19-2014, 06:13 AM
It only takes one cylinder to lock up the whole engine. Find that cylinder and repair the problem. Save your self some time and money.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 7 Old 01-19-2014, 07:16 AM
troykimber's Avatar
injector cups maybe...
95 sc lb 4x4 5 speed
ts 6 position chip, boost relief valve, 4" intake, 3" downpipe-5" rest of the way to a stack, fpr shim, twin 16" s-blade electric fans, poly bushings, zoom variable torque ceramic clutch with solid flywheel, hydroboost, stancor relay, exhaust brake, ss hpx line, 140v idm, bar and plate intercooler, glowshift gauges, gt grant signature series wheel with black billet hub, rockford door speakers- pioneer head unit- 2x 12" kenwood w3 subs
troykimber is offline
post #4 of 7 Old 01-19-2014, 01:54 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
Couple things come to mind. Old copper washer still seated in cup. Cracked cup. Dirt/oil in bolt holes for clamp downs preventing proper torque of bolts. Stuck open injector needle valve.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 7 Old 01-21-2014, 10:39 AM Thread Starter
dkapp0802's Avatar
I have more than 1 cylinder that's doing it. I poked at one of the cups that hydrolock ed and it looked fine with no seals in it. I have another cylinder that's doing it. Before this I had my ipr valve get stuck open due to the hpop screen getting demolished. So I'm thinking part of the screen getting lodged in the injector making it stick open. Is this possible?
6.0 powerstroke tan with black trim, egr delete. 2" leveling kit, white interior led upgrade, stc fitting upgrade
if it smoking, you aint strokin
post #6 of 7 Old 01-21-2014, 01:40 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
No, that would only cause a problem on the oil side of the injector. You would need a broken tip or a seal problem to let fuel, or possibly oil, into the cylinder. You could also have a cracked head that leaks when the engine is off. If the injector cup was cracked, you would get water in the cylinder when the engine is off, or possibly water in the fuel that could damage the nozzles on restarting.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 7 Old 01-21-2014, 02:36 PM
Im thinking improper hold down or sealing of the injectors. Since injectors are expensive, I would replace the hold downs, and reseal the injectors again. Label the injectors on cylinders that are hydrolocking, and move them to a dry cylinder. If the issue follows the injector(s), replace the faulty ones.
winnersdieseltech is offline
