oil n water mixed? need help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-18-2014, 03:41 PM Thread Starter
anybody know what causes this, and the solution...2004 6.0...10/03 build
ID:	228858   Click image for larger version
04250xlt is offline
post #2 of 8 Old 01-18-2014, 07:15 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
Does your engine oil look normal? As far as why you have oil there would be because of the engine's closed crankcase vent that allows a small amount of oil into the intake but the reason that the oil and water are mixed I would guess condensation
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #3 of 8 Old 01-18-2014, 07:19 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 331 Post(s)
X2 on what your oil looks like. Also remove the air valve while you're in there. 2 T15 screws hold it on.
@loxdce
LoxDiesel is offline
post #4 of 8 Old 01-19-2014, 06:51 AM Thread Starter
Engine oil is normal...if the vent you are talking about is the oil breather, then that can't be it, the oil ventilation on mine is between the MAF and the turbo on the air intake. Unless there is another hose from the crankcase going to that pipe, idk. That pipe looks like its coming from intercooler
04250xlt is offline
post #5 of 8 Old 01-19-2014, 06:54 AM
LoxDiesel's Avatar
Quoted: 331 Post(s)
Take a pic of what you're talking about
@loxdce
post #6 of 8 Old 01-19-2014, 07:20 AM
Air flow is from the drivers side to the passenger side of the CAC [Charge air cooler]
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #7 of 8 Old 01-19-2014, 08:11 AM Thread Starter
There is 2 pics on my first post
04250xlt is offline
post #8 of 8 Old 01-19-2014, 08:21 AM Thread Starter
I am getting a p0407 and p0488 code, I changed the egr valve and codes remain. Also the exhaust smells funny, almost like its burning rich or something, maybe...idk
04250xlt is offline
