Sensor Cleaning? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-17-2014, 05:22 PM Thread Starter
Question Sensor Cleaning?
I replaced my thermostat a couple days ago and when I did I had to pull my EBP sensor bracket off to get to it. While I had it off I took it apart and cleaned it out with just a dry Q-tip, and then kinda scraped out the elbow it connects to with the Q-tip stick, quite a bit of gunk and crusty soot came off and out. I have noticed a pretty good bump in MPG's since doing this, and will be pulling the whole EBP tube off so I can clean it out too! My question is: are there other sensors that I can take off and clean out to improve MPG's and performance? And what can I use to clean them? I thought about using PB Blaster but thought "I better not"! Will PB Blaster hurt my sensors? Should I just use some water with a couple "DROPS" of Dawn? Or is my dry Q-tip approach the best way? I'm thinking I'll be just buying all new sensors and replacing them, but in the mean time cleaning them is most cost effective :-) I have recently replaced my ICP sensor because it went out and leaked all down my driveway?
Bullmastiff07 is offline
post #2 of 6 Old 01-17-2014, 09:29 PM Thread Starter
Nobody has any info??
post #3 of 6 Old 01-17-2014, 09:53 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
I would just use electrical parts aresol cleaner for the sensor and then just use a thick piece of wire down the EBP tube to break up any blockage in it.
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
The Following User Says Thank You to juniorssrollin For This Useful Post:
Bullmastiff07 (01-18-2014)
post #4 of 6 Old 01-18-2014, 07:28 AM Thread Starter
That was my other thought, like some electra-clean and a Q-tip? Know of any other sensors that would help to clean out?
post #5 of 6 Old 01-18-2014, 07:39 AM
gotta_gofast's Avatar
Quoted: 62 Post(s)
I bought a brand new EBP sample tube from sunriseford (sponsor on here) for $12.xx which kicks the chit out of trying to clean an old rusty one. I also replaced the MAP line when I did the EGR delete. It had some oily substance occupying the hose that you find in the rest of the intake. Plus it was dry-cracked.
Its never a bad idea to periodically inspect your electrical harness, cooling system hoses and components, clean and inspect intercooler boots, ect... You can catch a problem before its a problem. Your monitor (if you don't have one GET ONE) will tell you a lot, but an old school mechanical inspection can tell you a lot, too.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
The Following User Says Thank You to gotta_gofast For This Useful Post:
post #6 of 6 Old 01-18-2014, 02:21 PM Thread Starter
Thanks GGFast!! I'll definitely check those, my strokin-wisdom is increasing by the day because of all you guys!
Tags
cleaning , ebp sensor , mpg , sensors
