Fuel problems - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-17-2014, 04:08 PM Thread Starter
Fuel problems
Ok so headed to work the other day and truck started sputtering and cutting out then died let it set a min crank on it some and fire up go about a mile or so then die again done this about three or four times I pulled the codes and crank shaft position sensor failure is what I was given changed the fuel filters and they have white cream colored jelly looking stuff on them I'm thinking I geled up which is weird cause I treat my fuel with howes so question is if it is geled when it warms up will it be normal again or am I hosed and any ideas on what to do
smokem if u gotem is offline
post #2 of 4 Old 01-17-2014, 04:17 PM
Blown F-150's Avatar
Diesel 911. It got me out of a gelling bind a couple of weeks ago when it was -35*
2006 F-350
Lariat, Crew Cab 4X4
EGR Delete, K&N Intake, MBRP Exhaust, Level kit, Custom Ford Badges, Tranny/EGT/Boost/Fuel Pressure Gauges.
Gryphon FICM tuner
SCT XCal 3 with custom tunes
ScanGauge II
Updated STC fitting
High idle mod, blue spring update.
Blown F-150 is offline
post #3 of 4 Old 01-17-2014, 04:33 PM Thread Starter
Is that what yours looked like and did it do that same kinda stuff and will it effect my injectors
post #4 of 4 Old 01-17-2014, 05:13 PM
I was lucky and caught my fuel pressure dropping due to gelling since I have a fuel pressure gauge.
Once I through the bottle of Diesel 911 in and topped up the fuel it only took 10 minutes of idling before my fuel pressure went back to normal.
I have seen gelling in my tractors before and yes it looks like what you described. I don't expect you ran it long enough to really damage your injectors, but low fuel pressure is known to cause them to fail.
Throw in new filters and a bottle Diesel 911, I believe it will get you going.
2006 F-350
Gryphon FICM tuner
ScanGauge II
Updated STC fitting
