6.0 rookie need help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-17-2014, 02:08 PM Thread Starter
504BOY's Avatar
I have a 06 6.0 Found out this week oil cooler was bad (have sludge in egas bottle) changed oil and oil filter today and added rev ex, started the truck and it ran normal for 15 minutes or so,i reved engine couple times and it stalled. Now it won't start!!! I having the oil cooler changed this wknd, puzzled what could be the problem?
504BOY is offline
post #2 of 4 Old 01-17-2014, 02:19 PM
Possible trash in the IPR hanging it open. The passage between the oil cooler valley and HP oil pump can get garbage in it when oil cooler service is performed. If you can monitor ICP and IPR duty cycle, you can determine if this is an ICP related issue.
winnersdieseltech is offline
The Following User Says Thank You to winnersdieseltech For This Useful Post:
504BOY (01-17-2014)
post #3 of 4 Old 01-17-2014, 03:09 PM Thread Starter
504BOY's Avatar
Do you think putting the rev ex in the oil freed up some gunk and stuck the ipr valve open? What should the pressure be on that ipr? I'll have my mechanic check tmrw
504BOY is offline
post #4 of 4 Old 01-17-2014, 03:14 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 402 Post(s)
Engine needs at least 500 psi to run.
@loxdce
LoxDiesel is online now
The Following User Says Thank You to LoxDiesel For This Useful Post:
504BOY (01-17-2014)
