2003 190K got hot towing swap for an 05???? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-16-2014, 06:52 AM Thread Starter
POWERSTROKE_HER's Avatar
there is oil in the truck. i was towing a 16foot flat bed with a supercab short bed 4x4 6.0. rolled over 190k during this tow.
truck is stock besides airaid intake and an exhaust from cat back.
ficm replaced a year and a half ago 3 injectors 2 years ago.
regular maintenace with rotella 15 40
should i mess with trying to trouble shoot this engine or just swap out for another engine i have with 100k???
i have a laundry list of parts around so i should be able to make it work.
or if i should just do an oil pump and head gaskets in my truck i just dont have the money or time to wait for the heads.
thanks guys any input is appreciated
POWERSTROKE_HER is offline
post #2 of 6 Old 01-16-2014, 07:31 PM
BRichards118's Avatar
I would pull out your current motor, drop the new/100k one in and slowly rebuild and bullet proof the one your having issues with. That way you can take your time and not have to drop a large chunk of change all at once on bullet proofing your motor and since the motor will be outta the truck it will be way easier to work on. I don't mind working on the 6.0s when the cabs off or when the motors out but working on them with the motor in is like pouring honey in my ears and sticking me on a ant hill lol
BRichards118 is offline
post #3 of 6 Old 01-16-2014, 07:41 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
The 6.0 is built to run for 300k miles without needing a major overhaul. So at 190k that motors got a lot of life in it. Over heating could be from something as simple as a failed t-stat or a slipping water pump, a failed degass bottle cap, a clogged egr etc. Have you tried any trouble shooting?
Do you have a monitor?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 6 Old 01-16-2014, 10:41 PM
Since you say you don't have to time to wait on the heads your not going to have much time to do anyother mods.
SO ya may as well swap her out if she is complete and running.
Keep in mind with a 03 to 05 swap you need to bring the ficm and pcm from the 05 with it as well as the engine harness. 05 uses a different strategy and has some sensor changes necessitateing the harness swap.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 6 Old 01-17-2014, 06:32 AM Thread Starter
No white smoke Out the tail pipe no smoke at all actually. But it got hot then temp gauge went off and then I lost oil pressure and truck shut off. Yesterday I pulled everything apart and found that half way down from where the fan clutch plugs in was cut.yt?
post #6 of 6 Old 01-17-2014, 06:54 AM Thread Starter
I was just trying to think easiest route. But if I need another computer ficm and harness I might as well spend the money on the 03.
Also the truck I was towing back
03 200k mi had coolant in the oil, or water, but it was milky thick and nasty drained it. Filled with new oil ran for a while no more milky just slight tinge from leftover. And there is still coolant in the truck. Could that be a cracked block head or head gasket or just an oil cooler??? Any input is great. It runs but is low on power once in drive or reverse. No idea how long it has been sitting but truck is beat up. Got it cheap. .....luckily. to bad to.tow killed my truck..
Any input on hpops??
