random miss fires on 6.0 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-15-2014, 04:12 PM Thread Starter
blkdrgn71's Avatar
Having problems with miss fires. did head gaskets with a Sinister Complete solutions, and updates. ran a scan with a program that ford would use. reset the Key in the pcm. Its the worst with stock program,80% of it goes away with a tune in it. Does it need a custom tune now. Here is a list of mods.
Large mouth intake elbow
6.4 banjo bolts
Blue spring kit
AFE closed air box
Batmowheel
4" down pipe no muffler
Arp studs
Has stock injectors still. Ran good before. leaky head gaskets going out degas bottle.
blkdrgn71 is offline
post #2 of 4 Old 01-15-2014, 04:28 PM
roche837's Avatar
Quoted: 5 Post(s)
Garage
Feedback Score: 4 reviews
codes? Did you run injector balance/ contribution and buzz test or test the glow plugs
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #3 of 4 Old 01-15-2014, 04:39 PM Thread Starter
blkdrgn71's Avatar
new glow plugs from Ford no codes are thown. Watched power balance on laptop its totally random they go low but in no pattern but evenly low.
post #4 of 4 Old 01-15-2014, 04:43 PM Thread Starter
blkdrgn71's Avatar
My guy is not an expert. but he thinks its running lean or needs injector timing needs to be /changed.
idles fine. Happens at 2000 to 3000 under load.
