OEM injectors - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Norwegian Viking
post #1 of 8 Old 01-15-2014, 12:45 PM Thread Starter
Norwegian Viking's Avatar
Send a message via MSN to Norwegian Viking
OEM injectors
So i gues i am in the market for new injectores.
Reading around, i think i like to go OEM, but what you all think ?
I was looking at thes 2 different injectors, but not sure about the sellers, one have 1 year warenty, and the other have 2 years.
The seller giving 2 years taking about other KNOCK OFF injectores ???? what is this ???
I put the 2 link up, so pleas tell me what you thinking
2 years warenty
Remanufactured 6 0L Powerstroke Diesel Early Build Fuel Injector F250 F350 | eBay
1 year warenty
https://www.injectorsdirect.com/prod...emanufactured/
Norwegian Viking
(from Norway)
PS: pleas visit my gallery and leave a coment
No Smoke No Power, No Power No Fun, No Fun No Life !
F250 PSD 6.0 2003. SCT x3, Smittybuilt stainless bullbar, Rollbar, 31/75-16 Procomp All Terrain on Mickey Thomson Cassic II 10x16", Procomp 2" lift leafs front, F350 blocks in rear, Procomp MX6 adjustable.
Norwegian Viking is offline
post #2 of 8 Old 01-15-2014, 01:19 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
Those may be both the same, depending on when the reman happened, since all of the wear parts are suppose to new. That being said, the 4C3Z-9E527-BRM do have the DLC coating on the plunger for sure. You could use either without being concerned about functionality, especially with them being Motorcraft.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 8 Old 01-15-2014, 02:28 PM Thread Starter
Tanx for that info.
Both the injectors have same PN: Motorcraft Part # 4C3Z-9E527-BRM
But can you pleas fill me in whit more info about the injector and this DLC coating ?
I never heard about that, and dont know what this is, what i understand from what you wrighting, i think this coating if to reduce stickion problem, and dosent my original injecortors hav that coting ?????
Norwegian Viking
(from Norway)
post #4 of 8 Old 01-15-2014, 02:49 PM
Quoted: 47 Post(s)
In 04 the injectors had a change to the spring clip that sits under the intensifier piston to minimize flexing of the plunger handle (to reduce chatter in the core barrel), and the plunger was coated in a process that is very hard and slippery (diamond like coating - DLC) that is plasma-vapourized onto the plunger at about 2 micron thickness. The old 03 injectors were carbide coated and suffered from wear.
There was nothing done for spool stiction until recently. Newer replacement spools bodies have a slight groove on the inner side of the coil body to reduce surface tension where it comes in contact with the spool. This and wear on the spools is why they are using new spools in these rebuilds.
Frank
Working for Toys
post #5 of 8 Old 01-15-2014, 02:56 PM Thread Starter
Thanx so mutch for clearing that for me.
So if i contact the seller and ask if his injector has a slight groove on the inner side of the coil body, then i shoud be safe to get the last updated injectores, yes ?
iHenry likes this.
Norwegian Viking
(from Norway)
post #6 of 8 Old 01-15-2014, 03:10 PM
Quoted: 47 Post(s)
The seller may not know. If they are remans from 2012+ they have them. In any case, the grove is not that big of a deal for a reman with a new spool.
Frank
Working for Toys
post #7 of 8 Old 01-15-2014, 03:19 PM Thread Starter
Ok thanx enyway, i just ask seller about the date of reman, i think the boxes have date marks on them.
But like you say, its not a big deal.
Norwegian Viking
(from Norway)
post #8 of 8 Old 01-16-2014, 10:34 AM Thread Starter
Label on box
I got picture on the label from the injector box from seller toady.
From what i can see, it shoud be ok to buy this injector, since the are not old
Norwegian Viking
(from Norway)
